HDMI source custom resolutions
I am working on a design that sources HDMI (using the block design copied over from Xilinx example HDMI design) using Vivado/SDK 2018.1 on a Kintex-7 device which is working using the pre-set resolutions defined in:
BSP/proc_mblz/lbsrc/video_common_v4_3/src/xvidc_timing.c
const XVidC_VideoTimingMode XVidC_VideoTimingModes[XVIDC_VM_NUM_SUPPORTED] =
/* Interlaced modes. */
{ XVIDC_VM_720x480_60_I, "720x480@60Hz (I)", XVIDC_FR_60HZ,
{720, 19, 62, 57, 858, 0,
240, 4, 3, 15, 262, 5, 3, 15, 263, 0} },
To use one of these resolutions I call the EnableColorBar function where I pass in the desired resolution setting from the above table into the "XVidC_VideoMode  VideoMode" pass parameter which ends up calling the following function:
TmdsClock = XV_HdmiTxSs_SetStream(HdmiTxSsPtr, VideoMode,ColorFormat, Bpc, NULL);
Can somebody possibly help me understand how I can create my own custom resolution I need to support?   I would like to setup:
- Htotal (pixels)
- Vtotal (lines)
- Hactive (pixels)
- Vactive (lines)
- H sync width (pixels)
- H front porch (pixels)
- H back porch (pixels)
- V sync width (lines)
- V front porch (lines)
- V back porch (lines)
- Frame rate (Hz)
Tim
Hi @tim_severance
I see.
Would you refer the following AR ?
https://www.xilinx.com/support/answers/68227.html
Hi @tim_severance
I suggest to calculate these parameters by CVT formula from VESA even if your product is for CEA-861 or other.
@watari,
   I already know the values I want to use are valid since they work in non-Xilinx hardware, I just need to know syntactically how do I apply these values in place of the pre-set values.   For instance would I setup my own struct with those values and use an instance of that struct in my function call?
Tim
Hi @tim_severance
I see.
@watari,
    Thanks.   That is exactly what I was looking for.
Tim
Hi @watari,
Is there any tools to calculate timing parameters from VESA? Could you give me a website links to download it?
I want to create my own custom resolution,but I don't know how to calculate it.
- Htotal (pixels)
- Vtotal (lines)
- Hactive (pixels)
- Vactive (lines)
- Frame rate (Hz)
Hi @gandics
I already mentioned before about custom parameter to @tim_severance.
Would you refer previous post ?
After that, you can find "VESA CVT formula" and "CEA-861".
You can search these words via ex. google and find the solution.
Or, I suggest to access VESA web site and search "CVT formula" on VESA's search box.
You can find the document which is written by EXCEL format.
Hi @watari,
I have read the previous post,and search "CVT formula" on VESA's search box.However, member downloads.
Thanks for your reply.I am a new learner,and I will search it via google to find the solution.
Hi @gandics
If you have an enough experience about programming, I suggest to refer source code of some video driver, ex. X window's open source code, too.
I guess you might be found the formula about CVT in these source code files.
Hi @watari,
Thank you! ^_^
