jcoffman98
HW IP configuration for VideoPhy driver
I'm looking at :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841797/Xilinx+Phy+VideoPhy+Driver
There is a image with a broken link which depicts the only supported IP configuration for the phy driver.  Do happen to have this image or can you fix the wiki so I can see what this configuration looks like?
Tags (2)
florentw
HI @jcoffman98
I should have fixed it. Could you verify?
Florent
florentw
HI @jcoffman98
Florent
jcoffman98
The link is fixed.  Thanks!
