daldoul
Hardware Co-Simulation error : INTERNAL_ERROR:Xst:cmain.c:3422:1.27 ?
I am using system generator to do Hardware Co-Simulation of my projects . I have to add to my project the  IP Divider Generator v3.0. So I start at first by testing the Ip core   (Divider Generator v3.0) alone with hardware Co-Simulation and it works.
After that, I added the ip core to my project but in Hardware Co-Simulation I get an error in the  Synthesis process  :
Loading core <dvider> for timing and area information for instance <Div>.
INTERNAL_ERROR:Xst:cmain.c:3422:1.27 -  Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
But  when I work with ISE Project Navigator (without System generator ), I don't get this Synthesis  error.
ambrosef
There may be different synthesis options used when running Sysgen as opposed to running from project navigator. You could check the synthesis reports.
What version of Sysgen/ISE are you using?
If possible, opening a webcase may help triage this further.
