Akai_N
Hdmi ip tx input configuration
Wanted to enquire if the hdmi 2.0 tx ip supports any other protocols apart from AXI at input side. If yes then how to configure that.
Tags (2)
yuko.2828
Hi there
In the GUI , you can set Video interface as a Native interface, but AXI4-stream is easier to use.
Best  regards.
watari
Hi @Akai_N
Would you refer the following URL ?
You can find example design.
https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_tx_ss/v3_1/pg235-v-hdmi-tx-ss.pdf#page=67
Best regards,
ashokkum
Hello @Akai_N ,
As addressed by @yuko.2828, our HDMI IP supports Native Interface also. The Native Interface option is available in our GUI. For Your reference, I'm attaching the image of the native video interface test setup. Please go through it.
Kindly let me know, If You have any concerns on it. I hope it will be helpful to You.
With Regards,
Ashok.
