bhanu27
How to SWAP MIPI P AND N for a data lane, C_DL_IO_SWAP parameter
We have an issue on our board where P and N lanes are swapped. I was wondering how can i swap P and N lanes for MIPI IP. I see following properties for MIPI RX subsystem IP.
C_DL1_IO_SWAP.
Let me know if anyone has successfully implemented IO SWAP using this parameter
bhanu27
Final Status is that I was able to resolve this issue by doing an ECO.
ebrahimm
Unfortunately, XILINX MIPI D-PHY IP does not support P/N swap.
Here is a similar question and answer on another forum thread where another solution is possible: https://forums.xilinx.com/t5/Video/Swap-polarity-MIPI-D-Phy-HS-LVDS-input/td-p/1021113
I hope this helps!
Ebrahim
bhanu27
Hi Ebrahim,
When C_DL_IO_SWAP parameter is True for lane 1 and lane2. The implemented netlist shows the N and P are swapped for Data lane 1 and Data lane 2. Please see snapshot attached.
Could you please check with the MIPI CSI2 RX IP team to see if there is any option to SWAP the P and N for a data lane.
Best Regards
florentw
Hi @bhanu27
As per the topic refered by @ebrahimm
C_DL**_IO_SWAP is a hidden parameter for internal debug. Please ignore.
This is not supported
karnanl
Hello @bhanu27
If your question is answered. Could you please kindly mark this post as solved ?
So other forum users can learn from your experience.
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our
Versal Blogs
bhanu27
