watari
How to capture HDMI signal
Hi all
I'd like to capture HDMI signal with vcu_trd or vcu_hdmirx (VCU TRD 2019.1) by gstreamer .
[Environment]
Board : ZCU106
Video Source : Laptop PC
Video Sink : network or storage
First, I make sure the status of HDMI by following commands.
# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/hdmi_info
Stream Info
        Color Format: RGB
        Color Depth: 8
        Pixels Per Clock: 2
        Mode: Progressive
        Frame Rate: 60Hz
        Resolution: 1920x1080@60Hz
        Pixel Clock: 148500000
Stream Timing
        HSYNC Timing: hav=1920, hfp=88, hsw=44(hsp=1), hbp=148, htot=2200
        VSYNC Timing: vav=1080, vfp=04, vsw=05(vsp=1), vbp=036, vtot=1125
Rx Info
Mode: HDMI
VIC : 16
Scrambled: 0
Audio
Format : L-PCM
Channels : 2
ACR CTS : 148326
ACR N : 6144
Link quality
Link quality channel 0 : excellent (0)
Link quality channel 1 : excellent (0)
Link quality channel 2 : excellent (0)
# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/hdmi_log
HDMI RX log
Initializing HDMI RX core....
Reset HDMI RX Subsystem....
RX cable is connected....
RX TMDS reference clock change
RX Stream Init
RX mode changed to HDMI
RX Stream Start
RX Stream is Up
# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/vphy_info
TX: QPLL0
RX: CPLL
TX state: idle
RX state: idle
QPLL0 settings
M : 0 - N : 0 - D : 0
CPLL settings
M : 1 - N1 : 5 - N2 : 4 - D : 4
RX MMCM settings
Mult : 10 - Div : 1 - Clk0Div : 20 - Clk1Div : 10 - Clk2Div : 20
TX MMCM settings
Mult : 0 - Div : 0 - Clk0Div : 0 - Clk1Div : 0 - Clk2Div : 0
DRU Settings
Version : 7
DRU is disabled
Rx Ref Clk: 148318208 Hz
DRU Ref Clk: 156250000 Hz
# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/vphy_log
VPHY log
GT init start
GT init done
RX frequency event
RX timer event
RX DRU disable
CPLL reconfig done
GT RX reconfig start
GT RX reconfig done
CPLL lock
RX reset done
RX MMCM reconfig done
RX MMCM lock
# gst-device-monitor-1.0
Probing devices...
Device found:
        name : Monitor of Built-in Audio Stereo
        class : Audio/Source
        caps : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                   audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                   audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        properties:
                   device.description = "Monitor\ of\ Built-in\ Audio\ Stereo"
                   device.class = monitor
                   alsa.card = 0
                   alsa.card_name = "DisplayPort\ monitor"
                   alsa.long_card_name = "DisplayPort\ monitor"
                   device.bus_path = /devices/platform/amba/fd4a0000.zynqmp-display/fd4a0000.zynqmp-display:zynqmp_dp_snd_card/sound/card0
                   sysfs.path = /devices/platform/amba/fd4a0000.zynqmp-display/fd4a0000.zynqmp-display:zynqmp_dp_snd_card/sound/card0
                   device.form_factor = internal
                   device.string = 0
                   module-udev-detect.discovered = 1
                   device.icon_name = audio-card
        gst-launch-1.0 pulsesrc device=alsa_output.0.stereo-fallback.monitor ! ...
Device found:
        name : Built-in Audio Stereo
        class : Audio/Sink
        properties:
                   alsa.resolution_bits = 16
                   device.api = alsa
                   device.class = sound
                   alsa.class = generic
                   alsa.subclass = generic-mix
                   alsa.name = ""
                   alsa.id = "\(null\)\ xilinx-dp-snd-codec-dai-0"
                   alsa.subdevice = 0
                   alsa.subdevice_name = "subdevice\ \#0"
                   alsa.device = 0
                   alsa.card = 0
                   device.string = hw:0
                   device.buffering.buffer_size = 65536
                   device.buffering.fragment_size = 32768
                   device.access_mode = mmap+timer
                   device.profile.name = stereo-fallback
                   device.profile.description = Stereo
                   device.description = "Built-in\ Audio\ Stereo"
        gst-launch-1.0 ... ! pulsesink device=alsa_output.0.stereo-fallback
Device found:
        name : vcap_hdmi output 0
        class : Video/Source
        caps : video/x-raw, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 32768 ], height=(int)[ 1, 8191 ], interlace-mode=(string)alternate;
                   video/x-raw, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)[ 16, 32768 ], height=(int)[ 1, 8191 ], interlace-mode=(string){ progressive, interleaved };
        properties:
                   udev-probed = true
                   device.bus_path = "platform-amba_pl\@0:vcap_hdmi"
                   sysfs.path = "/sys/devices/platform/amba_pl\@0/amba_pl\@0:vcap_hdmi/video4linux/video0"
                   device.subsystem = video4linux
                   device.product.name = "vcap_hdmi\ output\ 0"
                   device.capabilities = :
                   device.api = v4l2
                   device.path = /dev/video0
                   v4l2.device.driver = xilinx-vipp
                   v4l2.device.card = "vcap_hdmi\ output\ 0"
                   v4l2.device.bus_info = platform:vcap_hdmi:0
                   v4l2.device.version = 267008 (0x00041300)
                   v4l2.device.capabilities = 2216693760 (0x84201000)
                   v4l2.device.device_caps = 69210112 (0x04201000)
        gst-launch-1.0 v4l2src ! ...
The results seems fine. So, I run the following command to make sure pipeline on gstreamer.
However, I'm facing "Internal data stream error" on v4l2src0.
# gst-launch-1.0 --gst-debug-level=4 -v v4l2src device=/dev/video0 io-mode=4 num-buffers=1800 ! capsfilter caps="video/x-raw, format=(string)RGB, framerate=(fraction)60/1, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1" ! queue max-size-bytes=0 ! fakesink
I guess I need something to control HDMI Rx (or /dev/video0).
But I don't know how to control it.
Would anyone help me ?
xud
watari
I already knew how to capture HDMI signal with "vcu_gst_app input.cfg".
However, I'd like to know how to set the setting of like "vcu_gst_app input.cfg" by linux standard command. (ex. v4l2-ctl and media-ctl)
How do I do it ?
xud
watari
Hi @xud
Thank you for your reply.
I will check it later.
But I might ask some question.
florentw
Hi @watari
Do you have any update on this topic?
Thanks and Regards,
watari
Hi @florentw
Sorry for my late reply.
Unfortunately, I don't have enough time to try it. So, I haven't solved it yet.
However, it was good information for me.
So, I close this issue.
Best regards
