chaitusvk
How to config VDMA for video processing in PS with triple buffer mode
Hi .. i  newbie to video processing , i want to blank some pixels in video , i want to do this in PS
My idea is
1. config VDMA in triple buffer mode ,Buffers namely 0,1,2
2. Config VDMA in circular buffer mode .
3. At an instant  Write channel will write to Buffer " 0"
4 . i will process frame from buffer " 1"
5. Read channel will read from Buffer " 2"
 i want to use S2MM INTERRUPT  and check for  MM2S and S2MM buffer number in PARK PTR REG  so i can find free buffer ....
please confirm me
1. In circular buffer mode MM2s and S2MM work on different frame bufffer
2. Read/Write channel will change to next frame buffer after completion of current frame , in which fastion this happen
    say both MM2S and S2MM are configured with same start address
Thank you
Tags (2)
florentw
Hi @chaitusvk
please confirm me
If the genlock is properly configured, then yes they will work on different buffers
As you are in triple buffer mode this is not complicated. When the read or write pointer arrives at the end of a frame, it will go to the only available buffer (not the one which the other one is on and not the one it was previously on)
Florent
florentw
Hi @chaitusvk
please confirm me
Florent
chaitusvk
Thank you so much @florentw
