bhwxl123
How to constrain VDMA IP to make it uses all BRAMs instead of URAM
I am using VDMA IP with XCZU11EG device and it automatically uses URAM, and in my design the amount of URAM is not so enough and I want the VDMA to use only BRAM.
How to constrain or configure VDMA IP to make it uses all BRAMs instead of URAM?
Tags (2)
florentw
HI @bhwxl123
I do not think this is controlled by the AXI VDMA IP. You can try applying vivado synthesis settings to limit the number of URAMs. Refer to UG901
Florent
florentw
HI @bhwxl123
Florent
bhwxl123
Thank you very much for replying. I will try the synthesis settings or to optimize my whole project.
