embedded
Advisor
Advisor
How to create IP with a created interface Definition
I am going to create an AXI_through IP block to connect two Video blocks with some changes of handshaking signals - M_axis_tid to S_axis_tuser. I tried two methods: first I tried create and package new IP. I chose Create AXI4 Peripheral. However, AXIS port doesn't have s0_axis_tuser. Then I tried create interface Definition, selected from axis_rtl interface definition and saved two xml files in a directory. The question is that how I can create an IP from this xml file. I do need a block which has all the video signalings (axis_tid, axis_tuser,..). I took a look at UG1118 and UG994. I could not find the next step on creating IP after defining Interface Definition.
So, I would appreciate any help.
Hossein
embedded
Advisor
Advisor
Hi @florentw
Thanks for the follow-up. I was wondering where we can use those created interfaces in below picture?
As I could not find any document regarding how and where to use this created interface I created this post. However, I could eventually learn where and how we use it. When we have our own custom IP with specific interface signals we can use our created interface to show the Vivado how - logical connection - it must connect these custom interfaces - which pin of master to slave - in a custom IP with custom interface signals.
Hossein
florentw
HI @embedded
From what I understand you would like to have an IP automatically generated after creating an interface. Correct?
If this is the case, this is not possible. The IP which are created with the AXI4/AXI4-Lite are generated from templates. The templates are not adaptable if you create a new interface.
So you will need to create the HDL for your IP from scratch (and then you can package it as an IP)
Florent
joancab
In HLS it's easy to work with streams with side channel signals, you may want to have a look at it.
florentw
HI @embedded
Any update on this?
Florent
embedded
Advisor
Advisor
Hi @florentw
Hossein
embedded
Advisor
Advisor
Hi @joancab ,
Thanks for your comment. Could you please give me a hint in which HLS document I have to look for it?
Hossein
joancab
Besides the basic UG902, I used the definitions in ap_axi_sdata.h to work with Tlast in my case. These signals are just structure members in HLS that you can read/ write and give any specific meaning.
florentw
HI @embedded
Yes this is correct, the main use case would be in custom IPs
Florent
