wzab
Mentor
Mentor
How to create video pipeline with my own video source?
For test purposes I wanted to create a design, where my own IP core generates the test video signal, routed finally to framebuffer write IP core.
However I need to define the video pipeline in the DT:
&amba_pl {
  video_cap_tpg {
   compatible = "xlnx,video";
   dmas = <&v_frmbuf_wr_0 1>;
   dma-names = "port0";
   ports {
     #address-cells = <1>;
     #size-cells = <0>;
     port@0 {
     reg = <0>;
     direction = "input";
     vcap_in: endpoint {
	remote-endpoint = <????>;
The problem is, that in case of my own source I do not have a phandle to put in the "remote-endpoint".
What can I use as the input endpoint in such case?
I tried to use the video generator producing directly the AXI4-Stream video data and another one emulating the video stream compatible with "Video In to AXI4 Stream" and "Video Timing Controller", but I can't find the right solution.
What have I missed?
TIA & Regards,
Wojtek
florentw
Hi @wzab,
If this is a TPG, then the endpoint should be an output no? And you should have no input enpoint.
The enpoint should be to connect the TPG to the frame buffer
Florent
wzab
Mentor
Mentor
Thanks, I'll check that fix as soon as I have access to the system for which I have generated the TPG license.
Maybe I have misunderstood the meaning of the "direction".
However what in case if I want to use my own IP core to generate the video signal (or to use my own Video input interface). How can I enable it to be used as a valid endpoint for pipeline definition in DT?
Maybe it is enough to create a dummy node in the DT with just the video output?
&amba_pl {
   my_video_src{
     ports {
        #size-cells = <0>;
        port@0 {
          reg = <0>;
          direction = "output";
          mysrc_out: endpoint {
	     remote-endpoint = <vcap_out>;
  video_cap_my {
   ports {
     #size-cells = <0>;
     port@0 {
     reg = <0>;
     vcap_out: endpoint {
	remote-endpoint = <&mysrc_out>;
Is it enough, or should I somehow specify  in the DT the video format produced by my source?
TIA & Regards,
Wojtek
wzab
Mentor
Mentor
When I have changed endpoint to be an output:
&v_tpg_0 {
   clock-names = "fclk0";
   clocks = <&clkc 15>;
   reset-gpios = <&gpio0 55 1>;
   xlnx,vtc = <&v_tc_0>;
   ports {
      #size-cells = <0>;
      port@0 {
	reg = <0>;
	xlnx,video-format = <0>;
	xlnx,video-width = <8>;
	tpg_out: endpoint {
	remote-endpoint = <&vcap_out>;
&amba_pl {
  video_cap_tpg {
   ports {
     #size-cells = <0>;
     port@0 {
     reg = <0>;
	remote-endpoint = <&tpg_out>;
I get the following results:
v4l2-compliance  v4l2-ctl         v4l2-dbg         v4l2-sysfs-path
root@os_prj1:~# v4l2-compliance
Driver Info:
        Driver name   : xilinx-vipp
        Card type     : video_cap_tpg input 0
        Bus info      : platform:video_cap_tpg:0
        Driver version: 4.9.0
        Capabilities  : 0x84200002
                Video Output
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps   : 0x04200002
                Video Output
                Streaming
                Extended Pix Format
root@os_prj1:~# ffprobe /dev/video0
ffprobe version 3.1.3 Copyright (c) 2007-2016 the FFmpeg developers
  built with gcc 6.2.1 (Linaro GCC 6.2-2016.11) 20161016
  configuration: --disable-stripping --enable-pic --enable-shared --enable-pthrv
  libavutil      55. 28.100 / 55. 28.100
  libavcodec     57. 48.101 / 57. 48.101
  libavformat    57. 41.100 / 57. 41.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 47.100 /  6. 47.100
  libswscale      4.  1.100 /  4.  1.100
  libswresample   2.  1.100 /  2.  1.100
  libpostproc    54.  0.100 / 54.  0.100
[video4linux2,v4l2 @ 0x41a00] Not a video capture device.
So dev video0 is recognized as an output device.
Please note, that I need to use TPG (or my own source) as an emulated video source.
Wojtek
igorg
Hello Wojtek,
the endpoint of video_cap_tpg node (port@0) should have an input direction, not output. So your custom IP's (or TPG) endpoint will be an output in this case (and there is a link between them). Note, that dummy node in DT is not enough to get it to work, you will have to write some kind of dummy Linux driver which implements v4l2-subdev and media functionality for your own IP. Take a look at the TPG driver (drivers/media/platform/xilinx/xilinx-tpg.c) - it's a good example of such a driver.
Kind regards,
Igor
