Mentor
Mentor
How to do simulation my design with v_tc (Video Timing Controller), ZYNQ VIP and AXI VIP ?
Hi all
I already posted my question at other category. (https://forums.xilinx.com/t5/AXI-Infrastructure/How-do-I-execute-post-synthesis-functional-simulation-with-AXI/m-p/845739)
However, I can not resolve it.
Then, I modified my question and post my question again.
Would anyone help me ?
I'd like to clarify my understanding about the behavior of v_tc (video timing controller) by simulation.
However it seems protected IP. I can't pick up some signals under 2nd layer. I can pick up just IP top layer's signals.
[Question]
Q1) How do I pick up some signals under 2nd layer ?
Q2) If, Q1's anser is no, I'd like to do simulation with post synthesis functional simulation by xsim with AXI VIP and ZYNQ VIP. However AXI VIP and ZYNQ VIP can not be supported for post synthesis functional simulation mode. Do you have any idea to resolve my issue. How do I do to resoluve my question ?
Best regards
Re: How to do simulation my design with v_tc (Video Timing Controller), ZYNQ VIP and AXI VIP ?
@watari
It's more related to simulation.
You need to generate the post-synthesis simulation model from Video Timing dcp file firstly, and then add the post-synthesis simulation model as simulation only source to the project.
In that case, you should be able to use behavioral for VIP, but post-synthesis simulation mode for Video Timing Controller.
It's easier to do it using Modelsim, as you only need to modify the compile list in the do file, and use the post-synthesis simulation mode file name to replace behavioral simulation model name.
Or you can generate dcp for Video Timing controller in advance, and then package the dcp file as a custom IP, brings it to IPI, Vivado tool should use structural mode for simulation in this way.
Hi @watari,
Q1. I do not think there is any real solution to this in simulation. On thing you could do is to add an ILA on the internal signals in the synthesized design and run it in HW
Q2. The VIP should be synthesized as wire. I am not sure why you need to use the Zynq VIP here. For the VIP, you might be able to add it in your test bench (which won't be synthesized).
@watari
Mentor
Mentor
Hi @xud
Sorry for my late reply.
Unfortunately, I can use xsim or irun (Insicive Simulator).
However, I understood your explanation and already tried it.
