jinhanharu
How to generate NTSC timing by using VTC(Video Timing Controller)
I have to design NTSC 480i by using Zynq and ADV7123(Analog Device Video DAC component)
so I could get the image but there is an error.
sometimes, even,odd lines swaps so I checked the waveform but there aren't Equalizing pulses and serration pulses
when I read the PG016, VTC doesn't support  NTSC.
so I don't know how to generate the signals(equalizaing pulses and serration between even and odd fields)
my vtc is v6.1 and only generation mode(not detection mode)
Thank you in advance.
balkris
check page number 23
https://www.xilinx.com/support/documentation/ip_documentation/v_axi4s_vid_out/v3_0/pg044_v_axis_vid_out.pdf
Thanks and Regards
Balkrishan
