How to run HEVC HM Test Model in ZC702
Hello everyone, i'm new in fpga
I try to run HEVC HM Test Model application on Xilinx ZC702, So far I already did this :
1. I create new application in vivado sdk
2. I set the parameter like following :
    Project name : HM_encoder
    Hardware Platform : HM_bd_wrapper_hw_platform_0
    Processor : PS7_cortexa9_0
    OS platform : standalone
    Available templates : Empty Application
3. Then, I import the HEVC HM Test Model application like pict
After import the application, what should I do next?
Thanks in advance
Tags (3)
Hi @kaito87
Thanks and Regards,
Hi @kaito87,
Where this "HEVC HM Test Model application" comes from?
There is no Video Codec Unit in zynq-7000 (on ZC702) not even on the ZCU102 board so to run any HEVC on ZC702 you need an encoder in the PL. Do you have implemented any IP?
Thanks for reply @florentw
The application comes from here, and yes I already implemented IP from Vivado HLS but a very simple IP i think
I try to implemented that apps on ZC702
Hi @kaito87,
Could you detail more:
  • Which application exactly? There are multiple links in the page you shared.
  • What exactly did you do with vivado HLS? Where is the code coming from?
  • Could you explain how you are splitting between SW and HW? Do you have a schematic for this?
> It does not look simple to me. Not sure about what you've done
Note: We have partners which have IPs for HEVC (ex here). You might want to consider it (discuss this with your sales contact).
Hi @kaito87
Thanks and Regards,
