ssampath
How to test audio codec application using vivado tool ?
Hi Frinds,
I am new to Audio codec, I want to test Audio-codec , Is there any IP from xilinx to test this. please help or suggest any related info on this
NOTE: Any help or suggestions are highly appreciated.
Thank you
S Sampath
-Sampath
florentw
Hi @ssampath,
In 2018.1 you coan find the SPDIF/AES3 v2 IP for audio. Not sure if it is what you are looking for.
florentw
Hi @ssampath,
