09-08-2020 05:25 AM
In principle, I could use dynamic genlock plus triple buffer to ensure that there will have a stable video output(irrespective whether it is smooth playing or not)
To do so, I have to lower the clock associated with this slow IP so that it could complete the processing on time and could update the VDMA in a very slow manner. However,
According to the Product Guide for the core:
"In asynchronous mode, the frequency of s_axi_lite_aclk <= m_axi_mm2s_aclk or m_axi_s2mm_aclk."
Because of this, I have to slower the clock associated with s_axi_lite_aclk as well. But when I slower this clock to meet the above requirement, the screen starts flashing. But why?
As I am now running out of idea on how to ensure there will be a stable video output whenever a slow IP is connected. Any suggestion?
09-11-2020 03:32 AM
Hi @dr.elichan
The difference is that in case one you run at high frequency but play with the hanchecking signal while in case 2 you are running at low frequency
09-08-2020 09:20 AM
HI @dr.elichan
How slow is the "slow" IP?
I do not understand why you cannot run at a faster frequency... and I do not think reducing s_axi_lite_aclk is the correct option. The typical frequency for it would be probably around 50MHz. So the recommendation would be more try to run the streams clock faster. If an IP is not able to cope with this frequency, then the IP should apply backpressure (tready = 0) so it is not receiving data when it cannot treat it.
If what you are trying to do is do processing from the PS, then you should not try to lower the input frequency. But you should control the buffer pointer so you can keep working on a buffer and maybe drop frames on the input.
I believe you need to rethink your system and see the issue from a different angle.
09-08-2020 08:02 PM
the slow IP is given by my client to be used in a hdmi passthrough application. The video output of this slow IP is not at a constant rate.
As it is a video streaming scenario, what will be the effect if I insert a back pressure by sending tready=0?
Also, any example on how to insert back pressure?
hdmi in -->(dynamic genlock master)vmda 0(dynamic genlock slave)->slow IP->(dynamic genlock master) vdma 1(dynamic genlock slave)-> hmdi out
to be exact, where should the tready signal be connected?
09-08-2020 11:35 PM
HI @dr.elichan
The tready should be on the AXI4-Stream interface of the slow IP. This is how the IP will handle not beeing ready to process a new data.
Then the effect will just be that the VDMA0 will not send new data while the downstream IP is not ready.
09-09-2020 12:45 AM
will the connection below be enough to stop the VDMA0 from sending any data to the SLOW IP?
VDMA0(M_AXIS_MM2S_TVALID) <--- (IN_TREADY)SLOW IP
09-09-2020 01:07 AM
HI @dr.elichan
Yes, if tready is low, no data is transmitted. This is part of the basics of AXI:
09-09-2020 10:30 AM
many thanks for your reply. I have a much more clearer picture on how to pursue the testing.
1. By the way, what is the different between
vs
VDMA0(M_AXIS_MM2S) <--- (IN)SLOW IP
09-11-2020 03:32 AM
Hi @dr.elichan
09-23-2020 02:27 AM
Hi @dr.elichan
Is everything clear for you on this topic? If yes, could you kindly mark a reply as accepted solution to close the thread?
