princeling
I cannot view memory‘s change, while my VDMA correctly working!
Halo,everyone.
I use VDMA to build video channel in my vivado project, i use cmos sensor ov5640 to capture image,and it works well. My system is below
and my sdk code like below:
 * main.c
 *  Created on: 2019年05月10日
 *      Author: Administrator
#include "I2C_16bit.h"
#include "xiicps.h"
#include "xil_io.h"
#include "xparameters.h"
#include "sleep.h"
#define VDMA_BASEADDR	XPAR_AXI_VDMA_0_BASEADDR
#define VIDEO_BASEADDR0 0x01000000
#define VIDEO_BASEADDR1 0x02000000
#define VIDEO_BASEADDR2 0x03000000
#define VIDEO_BASEADDR3 0x04000000
#define VIDEO_BASEADDR4 0x05000000
#define POWER_DONE XPAR_SEND_POWERDONE_INFO_0_S00_AXI_BASEADDR
#define H_ACTIVE	1280
#define V_ACTIVE	720
#define H_STRIDE	1280
XIicPs	Iic;
int main()
	xil_printf("%d", Xil_In32(POWER_DONE));
	xil_printf("Sensor reset done\tIIC init start\r\n");
	I2C_config_init();
	Xil_Out32((VDMA_BASEADDR + 0x030), 0x108B);// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x0AC), VIDEO_BASEADDR0);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B0), VIDEO_BASEADDR1);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B4), VIDEO_BASEADDR2);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B8), VIDEO_BASEADDR3);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0BC), VIDEO_BASEADDR4);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0A8), (H_STRIDE*3));		// h offset (H_STRIDE* 3) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A4), (H_ACTIVE*3));		// h size (H_ACTIVE * 3) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A0), V_ACTIVE);			// v size (V_ACTIVE)
		/*****************从DDR读数据设置**********************/
	Xil_Out32((VDMA_BASEADDR + 0x000), 0x8B); 		// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x05c), VIDEO_BASEADDR0); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x060), VIDEO_BASEADDR1); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x064), VIDEO_BASEADDR2); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x068), VIDEO_BASEADDR3);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x06C), VIDEO_BASEADDR4);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x058), (H_STRIDE*3)); 		// h offset (H_STRIDE * 3) bytes
	Xil_Out32((VDMA_BASEADDR + 0x054), (H_ACTIVE*3)); 		// h size (H_ACTIVE * 3) bytes
	Xil_Out32((VDMA_BASEADDR + 0x050), V_ACTIVE); 			// v size (V_ACTIVE)
	while (1) ;
	return 0;
Actually, i can see very clear video caputered by camera on the monitor, but i wanna to access the image saved in ddr memory, then i open memory viewer in debug mode ,  nothing happened.
What solution i had tried?
I think the problem maybe vivado sdk, i uninstalled vivado2018.2, installed vitis and vivado2020.1 .. doest work ethier
I have been busy with this matter for many days, Thank u for help!
Tags (2)
princeling
Well, i found solution...
data to DMA is in cache,
use  Xil_DCacheFlushRange(DDR_BASE,Length)
in while(1), to Flush to ddr memory
