Import discontinued ip in newer Vivado
Hi, i want to use the old Scaler IP, i understand that i need to generate the output product in the old vivado and import them in the newer version.
I work with a device that wasn't present in the old Vivado, is this a problem?
I need the old scaler because i need to simulate the behaviour and the newer is not simulable
Hello @mrbietola ,
If  You want to go with new FPGA part on new vivado build, Then You have to call this IP from scratch and generate it. Because, You can't use the old IP reports of a different FPGA part of the old vivado build to new FPGA part. This is not correct.
So, Please call this IP for the FPGA of Your wish and try to generate it on the latest vivado build of Your wish.
Please note that, If the IP is discontinued in the new vivado build then You won't be able to see this IP in IP Catalog
Hope the above information will be helpful to You.
With Regards,
Ashok.
Hello @mrbietola
Adding to @ashokkum inputs, We will not able to support for discontinued IP's (in case if there is any issue)
Bhushan
