chldlrtjd
In DisplayPort 1.4 RX Subsystem (DisplayPort example), DP RX IP stops after 4~5 hours.
Dear Xilinx experts.
Thank you very much for your support and kind answers.
I implemented a design using DisplayPort 1.4 RX Subsystem (DisplayPort example).
My Vivado and SDK version is 2020.2. The device is xcku115-flvf1924-e-i.
My PC has GeForce GTX 1050 Ti graphic card with Windows 10 OS.
The DP Rx IP works well at start up, however DP RX stops after a 4~5 hours.
The DP_RX IP address is 0x44AC0000.
I checked the IP register map.
The difference between stopped condition and normal operation is as follows. All the other registers have same value in stopped condition and normal operation.
44AC000C: Enables the display timing generator in the user interface(value 1). 00000000(stop) 00000001(normal operation).
44AC02F0: [31:16] - Adaptive Sync Vertical Front Porch (VFP) derived based on Adaptive-Sync SDP reception. Assertion of Bit-31 of 0x070 has to read this register. 03A40000(stop) 02400000(normal operation).
44AC0114: Provides a mechanism for the host processor to monitor the state of the video datapath. This bit is set when vsync is asserted.
[3] - State of the vertical sync pulse for Stream 4.
[2] - State of the vertical sync pulse for Stream 3.
[1] - State of the vertical sync pulse for Stream 2.
[0] - State of the vertical sync pulse for Stream 1.
00000001(stop) 00000000(normal operation).
I don't know how to solve this problem.
I will really appreciate if I can be given solution or advice.
Thank you very much
Ick-Sung Choi.
watari
Hi @chldlrtjd
Which license are you using for DP ? Evaluation license or purchased license ?
I guess you're using an evaluation license.
If so, this behavior is limitation of evaluation license.
If you'd like to resolve it, you have to purchase a valid license for DP.
Hope this helps.
Best regards,
watari
Hi @chldlrtjd
Hope this helps.
Best regards,
chldlrtjd
Dear watari.
I am using Evaluation license.
Thank you very much.
