Inrevium + Display Port example issue with DRP access of VideoPhy
Hello
I am trying to run the DisplayPort TX example design then the passthrought example design for ZCU102 board + Inrevium TB-FMCH-VFMC-DP.
I have been able to generate and run successfully the Display Port 1.4 RX example design.
When I try to run the DP 1.4 TX I get the following error :
I have been able to figure out that the XVhy_DrpRd first call return in the PHY_Two_byte_set function return a failure.
I don't know if I am doing something wrong and I don't really now where to look to debug this issue.
More information on the setup :
- ZCU102 is a 0432055-05 number (new DDR4 chips) ==> I have found the fix of launching an fsbl without psu_init at the power up of the board and then launching the app (still without psu_init)
- The Inrevium board is attached to HPC0_FMC
- I have set VADJ_FMV to 1.8V on boot with the Board_ui.exe
- A computer is connected to the DP RX port and a 4K monitor to the DP TX port of the inrivium.
Do you have any idea to debug this situation ?
Thank you in advance for your answer,
Best regards,
Karvonz
Hello @florentw
I finally found the fix just before the week end and was going to put the answer this morning.
You were seeing right with my problem I was running the fsbl for the ZCU102 platform and not the DP platform just compiled.
It fixed the drp failed and the design run well then. It's a bit weird that I can run the DP RX with a wrong fsbl and not the DP TX :D
Thank you for your support
Best regards,
Karvonz
Hi @karvonz
Have you ever been updated a firmware of MSP430 which is Megachip's device ?
If no, would you update it whose firmware with a timestamp before July 5 2017 first ?
If you'd like to know the detail, would you refer a document of XTP433 ?
BTW, I'd like to know more detail to find a route cause.
Would you tell me the followings ?
- Would you use same version of tools between petalinux (boot loader), Vivado, XSDK and example design, if they are different ?
- What resolution and color depth do you choose at a computer ?
- Do you share your model name of 4K monitor ?
- Can you read DPCD register values by ex. Xilinx tool ?
Best regards,
Hi @karvonz
This is the first time I se an error "DRP access failed" with the DP1.4 example design.
You said that you run a fsbl. Can you confirm that you run the fsbl build for the hardware platform of the DP1.4 example design?
Can you get a register dump of the video phy after the failure?
Florent
Hello @florentw
Best regards,
Karvonz
HI @karvonz
My guess why the DP1.4 RX only example was working is because you have run the psu_init before running the fsbl without a power cycling of the board. Thus the clock was properly set.
Florent
@karvonz
I am trying to get the displauport 1.4 Rx subsystem to work. I have the example design loaded. But when i check the ILAs in the examplde design i see only 0's on TDATA. Meaning its just a black screen. Did you face anything similar?
Ska
