Interfacing monitor to zynq board
I have followed the video series 21 for to demonstrate the monitor interface.
I am getting these following results on the monitor but I am not getting anything on the monitor
1] TPG application on ZC702 using on-board HDMI
2] HDMI Monitor connected
3] HDMI Setup Complete!
4] TPG started!
Please give me solutions
It's working now, the issue is with respect to HDMI connector
 What debugging have you done?
HI madhu.n@sensesemi.com
Are you using the ZC702 board? Did you try with different HDMI cables?
What it the state of the LED DS19 on the board? If it is ON, then the issue is after the FPGA (ADV7511, cable or monitor)
Florent
The state of DS19 is ON,
The HDMI cable I am using has been tested witht the different setup the HDMI cable was good.
I should have to get the gree color display but I could not....
I have fallowed the vedio series 21,
I have verified the ADV7511 IC , Where I have red back the register configuration I can able to see the correct values.
But I am not getting the GREEN color display
According to the video series 21 ,The vid_active_video  pinout should be 15:0 , But In my block design by default it has 23:0 pinout
Hi madhu.n@sensesemi.com
  • The video series 21 is not showing how to build the design. Did you try with the HDF?
  • How did you build the desing? Did you use the video series 19? Even your video output are not connected so I guess you haven't started from the initial design
  • Are you using 2018.1? If not please use this version
Florent
I refered the video series 19 to build the block design. And then I followed the video series 20 and my code is detecting the HDMI cable connectivity. after that I followed the video series 21 to get some colors on the display.
Yes I am using this 2018.1
Did you try with the hdf file included in the video series 21?
Florent
Is it working for you know? If yes, could you share with the community what was the issue?
Florent
Do you mean that your ZC702 had an issue?
Florent
Yes
It seems that your issue is fixed.
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
