thejashree_13
Intra-clock violation for clkoutphy_out signal in MIPI CSI-2 RX Subsystem IP v4.1 in Vivado 2019.2
We are getting intra-clock violation for clkoutphy_out signal in MIPI CSI-2 RX Subsystem . We have already posted in forum regarding this
Please find the below link for the thread.
https://forums.xilinx.com/t5/Video-and-Audio/Intra-clock-violation-for-clockoutphy-out-in-MIPI-CSI-2-RX/m-p/1150930#M34408.
In the thread, the moderator has suggested to use Vivado 2020.1 version due to speed grade constraints of the device which we are using.
We just wanted to know , since we are not using that signal anywhere as it shown in the block diagram(See the link for the block diagram
)whether it is safe to ignore or does it affect any functionality of the MIPI IP?. We just wanted to know whether this clock is used internally for any purpose
With regards,
Thejashree
Tags (3)
bpatil
Hi @thejashree_13
This issue not related to MIPI CSI-2 RX SS IP or its signals. Its’ limitation of Vivado tool; there are no speed files available for xczu7cg-fbvb900-1-e device to support MIPI at 2500Mb/s lane rate. So, you need to use Vivado tools 2019.2.2 or later for XC devices.
Please check  ds925-zynq-ultrascale-plus:  Table 72: MIPI D-PHY Performance for more details.
EDIT: According to https://www.xilinx.com/support/answers/73633.html, I believe you can use Vivado 2019.2 without any issues.
Bhushan
bpatil
Hi @thejashree_13
Bhushan
thejashree_13
Hi @bpatil ,
Thank you so much for the quick response.
Where do I find 2019.2.2 version?
I am not able to find the this version for installation.
With regards,
Thejashree
bpatil
Hi @thejashree_13
Regarding difference between PetaLinux versions, the answer is No. 2019.2.2 version won’t be available as a public release, you need to use the 2019.2 or latest 2020.1 public release versions. I believe this is applicable for Vivado version as well; that's the reason @karnanl suggested you use Vivado 2020.1 in https://forums.xilinx.com/t5/Video-and-Audio/Intra-clock-violation-for-clockoutphy-out-in-MIPI-CSI-2-RX/m-p/1150930#M34408
Bhushan
thejashree_13
Hi @bpatil ,
Thank you so much for the clarification and will update the vivado version
With regards,
Thejashree
