zenic5o
Irregular resolution of HDMI IP
I have a question about HDMI IP(TX/RX) of Xilinx.
Can this IP process an irregular resolution video
signal(for example, 3840x1080, 1920x720etc.)?
I understand this question is too vague, so even
uncertain comments are welcome.
Thank you,
Tags (2)
ashokkum
Hello @zenic5o ,
HDMI Supports resolutions up to 4,096 x 2,160 @60 fps with RGB 8-bit, YCbCr 4:2:2 at 12- bits per component. So, the custom resolutions bandwidth should not overcome this bandwidth limit. For a custom resolution the customer need to update the timing table of the resolution. So, Could you please refer AR#68227. This Answer Record addressing the process of updating the timing table of the custom resolutions in software drivers.
I hope it helps to You.
With Regards,
Ashok
watari
Hi @zenic5o
What vertical frequency is your target resolution ?
Best regards,
zenic5o
Currently, vertical frequency is not fixed exactly, but under 60Hz.
Thank you,
karnanl
Hello @zenic5o
Just some comment.
Perhaps adding custom resolution in API can help.
https://www.xilinx.com/support/answers/68227.html
Leo
Versal Blogs
ashokkum
Hello @zenic5o ,
With Regards,
Ashok
zenic5o
Thank you all. I will refer to AR#68227.
Thank you,
ashokkum
Hello @zenic5o ,
Is Your issue get resolved?
If yes, Please mark the post as accepted solution, Which helps to You.
If not, Please provide more inputs to us to debug furtherly on this case.
With Regards,
Ashok
