songze
Is There A Way for MIPI CSI-2 TX to Transmit RAW16 Data
It is clear that RAW16 is not supported by MIPI CSI-2 TX SS in my last post.
https://forums.xilinx.com/t5/Video/Can-MIPI-CSI-2-TX-Subsystem-support-RAW16-transmission/m-p/1046375#M29002
I am wondering if it is possible to transmit RAW16 data using User Defined Data Types or RAW8 data type as defined in MIPI CSI-2 SPEC v1.1 (like one 16bit pixel transmitted as two 8bit data)? Or is there any other way to transmit RAW16?
Song
Tags (2)
karnanl
Hello @songze
Hmm, that is possible to do....
MIPI CSI-2 TX Subsystem will pack 1 RAW16 pixel into 2 RAW8 pixels. (you needs to set Data Tyoe and word count (tuser[63:48]) to suitable number)
The problem is how to receive those data.
Are you using Xilinx MIPI CSI-2 RX Subsystem as the receiver ?
Thanks & regards
Leo
Versal Blogs
songze
Hello @karnanl ,
Yep, I am using Xilinx MIPI CSI-2 RX SS.
I noticed RX SS can be configured as RAW8...So would this method work? But I guess the horizontal pixel number would double since RAW16 was chopped into two RAW8?
Thank you,
Song
karnanl
Hello Song
I believe this will work.  (But please note that we do not test it.)
Yes your understanding is correct.
Please note that MIPI CSI-2 TX only support spec v1.2.
So, even if Xilinx MIPI CSI-2 RX support RAW16, you must use CSI-2 RX with RAW8 setting for this usecase.
You may need to combine the 2 pixels into one RAW16 pixel on receiver side.
Leo
Versal Blogs
karnanl
Hello Song @songze
If your question is answered. Could you please kindly mark this post as solved ?
So other forum users can learn from the discussion here
Thanks & regards
Leo
Versal Blogs
