bruce_li
Is it possible to use MIPI CSI subsystem only in PL side ?
I want to use MIPI CSI subsystem only in PL side. Is it possible to run this IP core without PS driver ?
Thanks!
karnanl
Hello @bruce_li
Yes this is possible. Please ensure that reset is applied correctly.
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Hello @bruce_li
Thanks & regards
Leo
