License for Test Pattern Generator?
I have a node locked license for a Zybo and want to use the test pattern generator to create a VGA example, but I got a license error.
I use Vivado 2016.4 and my license manager looks like this:
How can I use the test pattern generator?
Re: License for Test Pattern Generator?
Okay found a solution. I have to add the license over the Manage License menu in my Account.
Doesn´t find the license on another way...
Hi @kampi ,
Just a note: from 2018.3, no license will be required for the TPG as well as some other video IPs (VTC, VPSS...)
