09-15-2020 04:18 AM
Whether MIPI CSI-RX Subsystem IP v4.1 license is bundled with vivado 2019.2 or do we need to purchase the IP license?
Currently I am using evaluation license in the design
With regards,
Thejashree
09-15-2020 04:33 AM
Hello @thejashree_13
Please use Vivado 2020.1 which has MIPI IPs license included.
See also : https://forums.xilinx.com/t5/Video-and-Audio/MIPI-license-2020-1/m-p/1119631
If currently, you are using an evaluation license with Vivado 2019.2, please continue.
Right now, I believe you cannot purchase MIPI IP licenses any more since it already included in 2020.1
Thanks & regards
Leo
09-15-2020 04:33 AM
Thanks & regards
Leo
09-15-2020 04:52 AM
Hi @karnanl ,
Thank you for the response.
Currently we are using Evaluation License. What does this Evaluation License consists of? Is there any timeout for this.
Whether we will be able to use the IP in 2019.2 same as 2020.1?
With regards,
Thejashree
09-15-2020 05:23 AM
Yes, time-out mechanism is enabled if you are using MIPI IP with an evaluation license.
There is a similar discussion regarding this topic, please see also :
https://forums.xilinx.com/t5/Video-and-Audio/MIPI-licensing/td-p/941298
For MIPI CSI-2 Rx Subsystem or MIPI CSI-2 TX Subsystem has time-out activated, all packets are reported as unsupported data types(ErrID) after time-out
[ For MIPI CSI-2 RX : which means Interrupt Status Register ISR[8] will get set Refer PG232]
[ For MIPI CSI-2 TX : which means Interrupt Status Register ISR[1] will get set Refer PG260]
Leo
