Meghuiyer25
MIPI CS2 + Video Frame Buffer: Device Tree pl.dtsi generated with no port definitions
Hello folks, Software v2020.1 Hardware: Zedboard + FMC + PCAM for Port A
I am trying to get an example setup running with the MIPI CSI 2 RX subsystem connected to the Video Frame Buffer to read it.
See the following diagram
As I export the hardware to Vitis to create the device tree files, the pl.dtsi is generated as shown below. It can be seen that in mipi_csi2_rx_subsystem_0 the ports entry is not created.
What I would expect are entries like:
csiss_ports: ports {
#address-cells = <1>;
#size-cells = <0>;
csiss_port0: port@0 {
/* Fill cfa-pattern=rggb for raw data types, other fields video-format and video-width user needs to fill */
reg = <0>;
xlnx,cfa-pattern = "rggb";
xlnx,video-format = <12>;
xlnx,video-width = <8>;
csiss_out: endpoint {
remote-endpoint = <&demosaic_in>;
csiss_port1: port@1 {
/* Fill cfa-pattern=rggb for raw data types, other fields video-format,video-width user needs to fill */
/* User need to add something like remote-endpoint=<&out> under the node csiss_in:endpoint */
reg = <1>;
xlnx,cfa-pattern = "rggb";;
csiss_in: endpoint {
demosaic_ports: ports {
#size-cells = <0>;
demosaic_port0: port@0 {
/* For cfa-pattern=rggb user needs to fill as per BAYER format */
reg = <0>;
demosaic_in: endpoint {
remote-endpoint = <&csiss_out>;
#size-cells = <0>;
reg = <0>;
reg = <1>;
#size-cells = <0>;
reg = <0>;
What I have
mipi_csi2_rx_subsyst_0: mipi_csi2_rx_subsystem@43c40000 {
            clock-names = "lite_aclk", "dphy_clk_200M", "video_aclk";
            clocks = <&misc_clk_0>, <&misc_clk_1>, <&misc_clk_0>;
            compatible = "xlnx,mipi-csi2-rx-subsystem-5.0";
            interrupt-names = "csirxss_csi_irq";
            interrupt-parent = <&intc>;
            interrupts = <0 29 4>;
            reg = <0x43c40000 0x1000>;
            xlnx,axis-tdata-width = <32>;
            xlnx,cal-mode = "NONE";
            xlnx,clk-io-swap = "false";
            xlnx,clk-lane-io-position = <0x0>;
            xlnx,clk-lp-io-swap = "false";
            xlnx,csi-en-activelanes = "true";
            xlnx,csi-en-crc = "true";
            xlnx,csi-filter-userdatatype = "false";
            xlnx,csi-opt1-regs = "false";
            xlnx,csi-pxl-format = "RAW10";
            xlnx,csi2rx-dbg = <0x0>;
            xlnx,data-lane0-io-position = <0x2>;
            xlnx,data-lane1-io-position = <0x4>;
            xlnx,data-lane2-io-position = <0x6>;
            xlnx,data-lane3-io-position = <0x8>;
            xlnx,dl0-io-swap = "false";
            xlnx,dl0-lp-io-swap = "false";
            xlnx,dl1-io-swap = "false";
            xlnx,dl1-lp-io-swap = "false";
            xlnx,dl2-io-swap = "false";
            xlnx,dl2-lp-io-swap = "false";
            xlnx,dl3-io-swap = "false";
            xlnx,dl3-lp-io-swap = "false";
            xlnx,dphy-lanes = <0x2>;
            xlnx,dphy-mode = "SLAVE";
            xlnx,en-active-lanes ;
            xlnx,en-bg0-pin0 = "false";
            xlnx,en-bg0-pin6 = "false";
            xlnx,en-bg1-pin0 = "false";
            xlnx,en-bg1-pin6 = "false";
            xlnx,en-bg2-pin0 = "false";
            xlnx,en-bg2-pin6 = "false";
            xlnx,en-bg3-pin0 = "false";
            xlnx,en-bg3-pin6 = "false";
            xlnx,en-clk300m = "false";
            xlnx,en-cnts-byte-clk = "false";
            xlnx,en-csi-v2-0 = "false";
            xlnx,en-exdesigns = "false";
            xlnx,en-timeout-regs = "false";
            xlnx,en-vcx = "false";
            xlnx,esc-timeout = <0x6400>;
            xlnx,exdes-board = "ZCU102";
            xlnx,exdes-config = "MIPI_Video_Pipe_Camera_to_Display";
            xlnx,exdes-fmc = "LI-IMX274MIPI-FMC V1.0 Single Sensor";
            xlnx,fifo-rd-en-control = "true";
            xlnx,hs-line-rate = <0x118>;
            xlnx,hs-settle-ns = <0xaa>;
            xlnx,hs-timeout = <0x10005>;
            xlnx,idly-tap = <0x1>;
            xlnx,init = <0x186a0>;
            xlnx,is-7series = "true";
            xlnx,is-versal = "false";
            xlnx,lprx-disable-extport = <0x0>;
            xlnx,max-lanes = <2>;
            xlnx,mipi-slv-int = <0x0>;
            xlnx,ooc-vid-clk = "6.666";
            xlnx,ppc = <1>;
            xlnx,rcve-alt-deskew-seq = "false";
            xlnx,rcve-deskew-seq = "false";
            xlnx,share-idlyctrl = "false";
            xlnx,stretch-line-rate = <0xdac>;
            xlnx,vc = <4>;
            xlnx,vfb ;
        misc_clk_1: misc_clk_1 {
            #clock-cells = <0>;
            clock-frequency = <200000000>;
            compatible = "fixed-clock";
        v_demosaic_0: v_demosaic@43c00000 {
            clock-names = "ap_clk";
            clocks = <&misc_clk_0>;
            compatible = "xlnx,v-demosaic-1.0", "xlnx,v-demosaic";
            interrupt-names = "interrupt";
            interrupts = <0 30 4>;
            reg = <0x43c00000 0x10000>;
            xlnx,s-axi-ctrl-addr-width = <0x6>;
            xlnx,s-axi-ctrl-data-width = <0x20>;
watari
Hi @Meghuiyer25
Did you make sure the following AR ?
https://www.xilinx.com/support/answers/75674.html
Best regards,
Meghuiyer25
hello @watari
After adding the patch and https://www.xilinx.com/support/answers/76392.html patch from this record. I still have same issue.
watari
Hi @Meghuiyer25
Would you share the followings to clarify my understanding ?
- related dts file which you got.
- fully boot log message
- clock frequency and source for AXI4 Stream on ex. demosic.
Best regards,
hokim
Your device tree is not complete: there is no DT node for image sensor(ov5640) and endpoint connections are incomplete
You should complete your device tree by referring to https://www.xilinx.com/Attachment/75268%20-%20Device-Tree%20changes%20and%20Patches%20required.pdf#page=11
You might need to patch ov5640 driver
https://forums.xilinx.com/t5/Video-and-Audio/petalinux-2020-2-ov5640-doesn-t-work/m-p/1183255#M35848
Meghuiyer25
 hi @hokim Thank you for the patch. I am using v2020.1 can I still use them? Before in v2019.1 I used to use a patch for pcam camera.
-> You should complete your device tree by referring to https://www.xilinx.com/Attachment/75268%20-%20Device-Tree%20changes%20and%20Patches%20required.pdf#page=11
In our case, we are mainly concerned for grabbing the frames in the sd card. is it necessary to include an audio block for frame write? we have an issue ( https://forums.xilinx.com/t5/Video-and-Audio/Petalinux-boot-freezes-while-booting/m-p/1241153/emcs_t/S2h8ZW1haWx8bWVudGlvbl9zdWJzY3JpcHRpb258S09ORlAzSUpJMFo5NkV8MTI0MTE1M3xBVF9NRU5USU9OU3xoSw#M38279  ) while saving the frames. Do you think it is because the node not complete in our device tree?
hokim
My patch can be applied to 2020.1
See MIPI CSI-Rx Pipeline  starting from page 11
Incomplete device tree for video pipeline doesn't make /dev/mediaX
Meghuiyer25
thank you for the patch,
Could you please highlight the incompleteness of the device-tree? I have not really understaood what is missing. My pipeline is
Meghuiyer25
Hi @watari
- related dts file which you got. ( pl attached )
- fully boot log message ( putty log )
- I/P clock frequency 100MHz and source for AXI4 Stream on ex. demosic.- 150MHz
hokim
Your figure is good
But your devicetree is not consistent with your figure
Where are the DT nodes of ov5640 and vcap?
Meghuiyer25
hi @hokimhere is my device treee
please check.
Meghuiyer25
hi @hokim
did you get sometime to have a look on the device-tree?
