MIPI CSI-2, D-phy Tx - DPHY-CLK-200m crystal oscillator requirements
@karnanl
Hi Leo.  You helped me about 1.5 years ago to get my SPARTAN 6 with the MIPI CSI-2, D-phy IP core to send 1080p50/60 video.
We need to substitute a different 200MHz LVDS crystal oscillator for the one we have used so far.
What are the minimum required jitter specs. and ppm required for this oscillator?
Hello Bruce
I believe you are using Spartan-7, since Xilinx MIPI IPs cannot be implemented in 6-series devices.
This dphy_clk_200M is connected to a MMCM.
So, MMCM input clock jitter/duty requirement shall be met. Please see also DS189.
( There is no ppm requirement since you are using MIPI TX IPs only )
Leo
Hello Bruce
Leo
You're right.
Thanks Leo for the quick answer!
