jagadeesh10
MIPI CSI-2 Rx Example - HDMI Output
Implemented MIPI CSI-2 Rx Subsystem Application Example for Zynq® UltraScale+™ ZCU102 Rev 1.0 board. After program FPGA and executing the application, I'm seeing Error programming free mode SI5324.
i'm not seeing any Video output.
Jagadeesh
Tags (2)
florentw
Hi @jagadeesh10,
If everything is clear for you on this subject, please kindly mark a reply as solution to close the topic. Else please reply to the topic
Thanks and Regards,
Florent
florentw
Hi @jagadeesh10,
Which version of vivado are you using?
It seems to be the same issue as mentioned here (even if not same example design):
https://forums.xilinx.com/t5/Video/ZCU102-HDMI-example-design-error/td-p/834841/page/2
Could you check your SDK settings?
Florent
florentw
Hi @jagadeesh10,
Thanks and Regards,
Florent
