Calvin
MIPI CSI-2 TX subsystem Virtual channel
Transmission of two different image format through MIPI CSI 2 TX subsystem Ip
Data type = RAW8 for both image formats whereas the number of active lines per frame is different on both
I intend to enable Register based Frame end generation
Is this the scenario where two different virtual channels are used for different image format?
Also what values can s_axis_tdest take and what do they indicate?
karnanl
Hello @Calvin
This use case should be supported.
No, register based Frame-end generation features and Virtual Channel is not related.
# But if you do enable “register based Frame-end generation features “
   You need to set Line Count Registers for each Virtual Channel correctly.
s_axis_tdest = 2’b00 -> Virtual Channel 0
s_axis_tdest = 2’b01 -> Virtual Channel 1
You can use Virtual Channel 0,1,2,3.
Please see also PG260 table 2-2 for example.
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
Calvin
Thanks for the reply!
"But if you do enable “register based Frame-end generation features “
   You need to set Line Count Registers for each Virtual Channel correctly"
Image format 1: frame resolution 2000x2000 -> active image -> 1600pixels x1800lines
Image format 2: frame resolution 2000x2000 -> active image -> 1200pixels x1400lines
  1. Virtual Channel Line Count Register value for image format1 = 1800 and image format2 = 1400 ?
  2. if vc0 is used for both image formats then the Virtual Channel Line Count Register needs to be updated dynamically based on the frame format being transmitted?
karnanl
Hello @Calvin
Yes. That is correct.
It should be possible, but hard/tricky to do. Since you need to change the register value between frames.
Other alternatives :
a. Disable "register based Frame-end generation features"
    Let MIPI CSI-2 TX generate FE short packet just before sending the next FS short packet.
b. Use VC0 for Image format 1 and VC1 for Image format 2.
Kind regards,
Leo
