MIPI D-PHY v1.2 TX implementation on the VU9P device on a VCU118 board
We are designing an FMC+ daughter card for the VCU118 board to support multiple MIPI D-PHY v1.2 TX connectors. For implementing the MIPI D-PHY TX controller in the FPGA, we are referring to the following documents:
* PG202 (v4.1) December 10, 2018
* XAPP1339 (v1.0) October 31, 2018
From these documents it appears that the "LP Receiver" functionality (reverse data communication) is NOT supported by the MIPI D-PHY controller. Isn't this functionality required in a host device to be compliant to the MIPI specification v1.2 ?
Ramana
Hello Ramana @ramanar
Xilinx MIPI D-PHY IP (at present 2018.3), only support MIPI D-PHY spesification ver1.1
Bi-directional data lane is an optional features of MIPI D-PHY specification. ( both on ver1.1 and ver1.2)
Please refer to chapter 4 of the specification document.
Thanks & regards
Leo
Thanks & regards
Leo
