cicilala
MIPI DPHYHi
I'm wondering if you are planning to upgrade MIPI DPHY IP to be compliant to DPHY specification 2.5. The present DPHY IP only support MIPI DPHY spec 1.2.
karnanl
Hello @cicilala
Right now, We don’t have a plan to support D-PHY spec ver2.5. It is a very new spec.
BTW, Do you have a target application that requires MIPI D-PHY ver2.5? A new sensor perhaps?
What is the MIPI D-PHY ver2.5 spec required in your target application? ( 4.5Gbps line-rate support ? Long-channel support ? Power Saving features ?)
Thanks & regards
Leo
Versal Blogs
cicilala
Hi Leo,
We want to support sensor with USL feature in the near future. MIPI D-PHY 1.2 does not support the USL feature.
karnanl
Hello @cicilala
Unified Serial Link (USL) is a new added feature MIPI CSI-2 ver3.0.
https://www.mipi.org/new-version-of-widely-used-camera-imaging-interface-mipi-csi-2
We don’t have any milestone to support MIPI CSI-2 ver3.0 since our device IO pins do not support bidirectional data lanes.
Thanks & regards
Leo
Versal Blogs
cicilala
Got it! Thanks!
