MIPI RX Design Simulation Doesn't Work
 I want to use mipi d-phy rx in my pl project.
But I'm not familiar with this IP, so in my own simulation project , this ip dosen't work . When the "core_rst" is complete,the "init_done" is not from "0" to "1".
Where can I get some simulation examples about  mipi d-phy rx ?
Thanks!
HI @shixiaoke
As mentioned by @dpaul24 , all the steps to generate the example design for the MIPI D-PHY IP are mentioned in the PG202
@shixiaoke,
RT*D.....the xilinx docu has an example_design which should explain how simulating the core works.
MIPI D-PHY v4.1 LogiCORE IP Product Guide - Xilinx
FPGA enthusiast!
All PMs will be ignored
HI @shixiaoke
