shixiaoke
MIPI RX Design Simulation Doesn't Work
 I want to use mipi d-phy rx in my pl project.
But I'm not familiar with this IP, so in my own simulation project , this ip dosen't work . When the "core_rst" is complete,the "init_done" is not from "0" to "1".
Where can I get some simulation examples about  mipi d-phy rx ?
Thanks!
Tags (2)
florentw
HI @shixiaoke
As mentioned by @dpaul24 , all the steps to generate the example design for the MIPI D-PHY IP are mentioned in the PG202
Florent
dpaul24
@shixiaoke,
RT*D.....the xilinx docu has an example_design which should explain how simulating the core works.
MIPI D-PHY v4.1 LogiCORE IP Product Guide - Xilinx
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
florentw
HI @shixiaoke
Florent
