10-25-2019 12:17 PM
MIPI design example simulation doesn't work! (Vivado 2019.1).
to reproduce:
I've noticed these line in the TB:
parameter CLK_PERIOD = 5;
always #(CLK_PERIOD/2.0) clk_100MHz = ~clk_100MHz;
That looks wrong to me.
I've changed :
parameter CLK_PERIOD = 10;
Still not working - I never see anything come out our of MIPI core!
Any ideas?
11-05-2019 10:12 AM
1. IMO, the clock period should be fixed (see my original post)
2. I suggest to update the doc and clearly mention that 1.2ms wait is necessary
10-25-2019 03:15 PM
After waiting for 1ms, I've got the output of MIPI TX core.
Should the clock period being fixed, then?
10-26-2019 03:52 AM
Hello @ifutritski
It should work with the default setting. Try to run the sim until 1,2ms.
If this is not working, please share the waveform screenshot.
Leo
11-05-2019 08:18 AM
Hi @ifutritski
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
11-05-2019 10:12 AM
11-12-2019 11:50 PM
Hello @ifutritski
1. I cannot find the same signal in my MIPI D-PHY example design,
but I think we do not have to change anything on the testbech to make MIPI D-PHY Example design run correctly.
2. MIPI D-PHY TX Initialization time (T_INIT) is set as 1ms as default, TX will have to drive LP-11 for a period longer than T_INIT, before TX start sending any HS data.
Perhaps we can add some notification in PG, I shall give your feedback to our developer team.
3. If you wish to speed-up MIPI D-PHY simulation , we do have an a parameter to do this. (CONFIG.C_EXAMPLE_SIMULATION)
attached two tcl script. Please run both to compare the simulation speed.
Thanks & regards
Leo
