ifutritski
MIPI design example simulation doesn't work!
MIPI design example simulation doesn't work! (Vivado 2019.1).
to reproduce:
  1. create a design example project
  2. run simulation
I've noticed these line in the TB:
parameter CLK_PERIOD = 5;
always #(CLK_PERIOD/2.0) clk_100MHz = ~clk_100MHz;
That looks wrong to me.
I've changed :
parameter CLK_PERIOD = 10;
Still not working - I never see anything come out our of MIPI core!
Any ideas?
Tags (2)
ifutritski
1. IMO, the clock period should be fixed (see my original post)
2. I suggest to update the doc and clearly mention that 1.2ms wait is necessary
ifutritski
After waiting for 1ms, I've got the output of MIPI TX core.
Should the clock period being fixed, then?
karnanl
Hello @ifutritski
It should work with the default setting. Try to run the sim until 1,2ms.
If this is not working, please share the waveform screenshot.
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
aoifem
Hi @ifutritski
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
ifutritski
karnanl
Hello @ifutritski
1. I cannot find the same signal in my MIPI D-PHY example design,
    but I think we do not have to change anything on the testbech to make MIPI D-PHY Example design run correctly.
2. MIPI D-PHY TX Initialization time (T_INIT) is set as 1ms as default, TX will have to drive LP-11 for a period longer than T_INIT, before TX start sending any HS data.
    Perhaps we can add some notification in PG, I shall give your feedback to our developer team.
3. If you wish to speed-up MIPI D-PHY simulation , we do have an a parameter to do this. (CONFIG.C_EXAMPLE_SIMULATION)
    attached two tcl script. Please run both to compare the simulation speed.
Thanks & regards
Leo
