MIPI interface
Hi Xilinx Team,
I would like to know, The HP I/O banks only supports the MIPI lane interfaces in XAZU7EV zynq ultrascale+ MPSoC Device?  or if any other banks supports MIPI interface please provide the details..
Thank you!!!!
Gajendiran A
karnanl
Hello gajendiran.a@tataelxsi.co.in
Yes, your understanding is correct.
For UltraScale+ devices you need to use HP IO banks to implement MIPI interface.
UltraScale+ datasheets and PG202 mention these:
Kind regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
Thanks for your update,
We are using xczu7evfbvb900 package in our design.
We have a DDR requirement where we need 64-bit DDR3 interface so I have used Bank 64/65/66 completely.  In addition to above requirement we need to interface two 4 lane CSI MIPI interface to this FPGA. And for MIPI I can’t use other than HP bank which is 64/65/66.
So my question would be can I use another bank other than 64/65/66 for interfacing DDR so that I can accommodate MIPI in one of this bank
karnanl
I believe you cannot.
zu7ev-fbvb900 has 3 HP IO banks (Banks 64,65,66), you need to implement MIPI interface on HP IO banks.
Bank 47,48 does not support MIPI_DPHY_DCI IO standard.
Leo
Hi Leo,
Thank you for the update...
Yes I can understand MIPI can be configured only in HP Bank (64,65,66). But for my case this banks  64,65,66 are assigned to PL DDR 64 bit completely...So is it possible to assign PL DDR to other bank (other than HP Bank).So that I can accommodate 2X 4 lane CSI MIPI in one of this bank(64,65,66).
Thank you !!!
karnanl
>is it possible to assign PL DDR to other bank (other than HP Bank) ??
I don't think so. PL DDR also requires HP IO bank.
Leo
Hello Leo,
Thank you for your update...
Additional to this we have requirement of 64 bit DDR interface and 2X 4 MIPI interface. The 64 Bit DDR signal are mapped in HP bank(Bank 64,65&66) and 2X 4 MIPI signals also mapped in same HP bank (Bank 64). Here Bank 64 is used to DDR signal as well as MIPI signals and the bank 64 voltage is 1.2V both working in same voltage.
Is it possible to configure DDR and MIPI interface in the same Bank(Bank 64). Please confirm about electrical speciation combabilities and other specification.
Gajendiran A
karnanl
Each HP IO bank of UltraScale+ devices consisted of 4 byte-groups.
You need to use 2 byte-groups to implement 2 instances of MIPI CSI-2 RX@4lanes. ( see above )
You can use the rest of the byte-groups for other purpose/IP.
For DDR4 I/O pins requirement please see : ug899 Chapter4. You need Memory Bank/Byte Planner for MIG IO planning. Please address your MIG related questions here : Memory Interfaces and NoC
Kind regards
Leo
