MPSoC+VCU+TRD+2018.2 DM3 sdirxtx Record test_1.mp4 can not be played
I have some troubles when working with ZCU106
DEMO BOARD: ZCU106-G
DEMO CASE: MPSoC+VCU+TRD+2018.2 DM3 sdirxtx
IMAGE:rdf0428-zcu106-vcu-trd-2018-2/images/sdirx_vcu_sditx/*
SDI INPUT SRC: BMD DIG CAMERA 1080P@60HZ
SDI OUTPUT MONITOR:BMD MONITOR
1.display issue: sdi input , monitor display ,I pass, I can see the input video on bmd monitor !
2.record issue: I get test_1.mp4 from usb disk. but I don't kown how to play it ! I have try VLC (both windows 7 OS and ubuntu 16.4 OS), but fail! which application can play test_1.mp4?
attachment is my test_1.mp4 .
Hi, I found the newest demo VCU+TRD+2018.3 have been modified this problem。the MP4 can be played by VLC!
thank you for your help!
Hello @williamxie
First of all I will recommend you to move to 2018.3 version of TRD
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/31686693/Zynq+UltraScale+MPSoC+VCU+TRD+2018.3+-+SDI+Video+Capture+and+SDI+Display
Please try ready to test images for above application and let us know if it works.
Now coming back to your original application:
May I know if you see the blue screen once ready to test images boot from the SD card ?
Please run following steps if it doesn't and also make changes to modetest command if you are working on full HD resolution
Once you see the blue screen Please run the record pipeline from given different resolution options.
Please choose recording path from one of the options given in this TRD(SATA, USB and SD card)
make necessary changes into following path in the config file and run the gstreamer function by calling the config file.
now to play the recorded file set the input path in the config file same as above and call the Gstreamer function with the edited config file.
along with above steps please answer following questions:
1. rev of zcu106 ?
2. are you using any SDI converter from board to display ? if yes what is the vendor you are using ? Do you see lock on the converter box ?
3. Or are you using DP cable to display ?
Hope this helps
Thank You
Hello @williamxie
May I know if my explanation helped you resolve your query ?
Please let us know if you have further questions or conclude this post by accepting the solution.
Thank you
