chance189
Mipi CSI2 Pin Assignment Tab Not Displaying
Hello all,
I am trying to instantiate the MIPI CSI-2 RX Subsystem Version 5.1, on Vivado 2021.1. My operating system is Ubuntu 18.04 LTS. I am targeting the xc7k160tffg676-2. From the guide (PG232) I was expecting an acceptable pinout to be found on the "Pin Assignment" tab. Is this no longer available in Vivado 2021.1?
Thanks for any help,
Chance
karnanl
Hello @chance189
7-series LVDS IO support for 1500Mbps line-rate, but for some package it is limited to 1250Mbps.
PG202 Chapter 5 describes that
Please ensure that
1. Your design can meet 1400Mbps timing constraint.
2. Your system has a reasonable good signal integrity to transfer 1400Mbps line-rate MIPI D-PHY signal.
Kind regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
watari
Professor
Professor
Hi @chance189
7 series doesn't support directly MIPI D PHY. So you can't use it.
Would you refer the following ?
https://www.xilinx.com/support/documentation/application_notes/xapp894-d-phy-solutions.pdf
chance189
Hello @watari
Thank you for your quick repy! I'm using the Meticom 20901 for a 4 lane Mipi D-PHY to LVDS. Due to CSI-2 being DDR, the max rate support should be 1400Mb/s as specified in table 17 of DS182, correct? So I'll just have to specify the pinouts manually then.
Chance
karnanl
Hello @chance189
Please ensure that
Kind regards
Leo
