NV12 stream byte pattern on Frame buffer video stream
I am looking for NV12 stream byte patterns (stream got from m_axis_video port of Framebuffer read, which reads stream from VCU decoder).  However, as I refer from the FB IP, the YUV 4:2:0 format has the following pattern:
* For even lines, 2 pixel per clock
47:40
39:32
31:14
23:16
15:8
7:0
Zero padding
Zero padding
V0
Y1
U0
Y0
* For odd lines, 2 pixel per clock
47:40
39:32
31:14
23:16
15:8
7:0
Zero padding
Zero padding
Zero padding
Y1
Zero padding
Y0
* But when I check with ILA, and see the successive lines, the above pattern does not match. Could you please let me know where could I find the correct one?
My aim is at reading AXI4 stream to 2 xf::Mat objects (Y and UV, separately). Is there any handy way to solve this?
Hi @peakpeak
Some IPs are not doing the zero padding. They are still outputting data that the downstream IP should ignore. I guess this is what is happening here
Florent
Hi @peakpeak
Florent
