tyoung
Need the schematic for the Inrevium TB-FMCH-VFMC-DP
We are having trouble with the design implementation for Displayport RX routed to the HTG930 using the driver support from Inrevium based on their TB-FMCH-VFMC-DP board.
We need the schematic for this board to track the signal assignments.
We have the user manual. We need the schematic.
barriet
At risk of asking the obvious, have you checked with Inrevium?
I don't know how they don't do it but there seems to be several different approaches out there from board vendors:
-freely provide schematic to anyone openly
-only provide them if you purchase the board
-no schematics provided  - work from the user guide or other docs.
I'm not sure which camp they fall into to but would start there.
Cheers,
bt
florentw
HI @tyoung
I believe Inrevium is providing the schematic if you buy the board.You might want to contact them directly as @barriet mentioned
Florent
