No HDMI TX SS video output on ZCU102
Hello all,
I am trying to build a simple DVI loopback on the ZCU102 and having some problems.
I have successfully built and tested the TRD video design and got working output. My setup is laptop -> ZCU102 RX-SS-> TX-SS -> Monitor, using Vivado 2018.3 and Petalinux 2018.3 on Ubuntu.
With my own Vivado design things do not work as well... My RX is working, and using the Xilinx EDID I see the right device, and am able to verify that video traffic goes in. The TX side does not seem to lock. Here's what I get for the log:
cat /sys/devices/platform/amba_pl\@0/a0020000.v_hdmi_tx_ss/vphy_log && cat /sys/devices/platform/amba_pl\@0/a0020000.v_hdmi_tx_ss/hdmi_log
VPHY log
GT init start
GT init done
TX frequency event
TX timer event
QPLL reconfig done
GT TX reconfig start
GT TX reconfig done
RX frequency event
RX timer event
RX DRU disable
CPLL reconfig done
GT RX reconfig start
GT RX reconfig done
CPLL lock
RX reset done
RX MMCM reconfig done
HDMI TX log
Initializing HDMI TX core....
Initializing VTC core....
Reset HDMI TX Subsystem....
TX cable is connected....
TX Stream Start
The TX Stream Up is missing... And the locked pin on the TX-SS is Low. However, the LOL signal from the Si5324 also goes low during Petalinux boot-up as it should...
My DTS is below:
&amba_pl {
	/* 114.285MHz reference crystal (X9 on ZCU102 rev. D1) for Si5324 clock for HDMI */
	/* IIC controller with Si5324 clock generator and DP159 retimer for HDMI TX */
	refhdmi: refhdmi {
		compatible = "fixed-clock";
		#clock-cells = <0>;
		clock-frequency = <114285000>;
	IIC_Fabric: i2c@a0050000 {
		status = "okay";
		compatible = "xlnx,xps-iic-2.00.a";
		/* interrupt-parent = <&axi_intc>; */
		/* interrupts = <5 2>; */
                interrupt-parent = <&gic>;
	        interrupts = <0 93 4>;
		reg = <0x0 0xa0050000 0x0 0x10000>;
		clocks = <&axi_lite_clk>;
		#address-cells = <1>;
		#size-cells = <0>;
		/* Si5324 i2c clock generator */
		si5324: clock-generator@68 {
			status = "okay";
			compatible = "silabs,si5324";
			reg = <0x68>;
			#size-cells = <0>;
			#clock-cells = <1>;
			/* input clock(s); the XTAL is hard-wired on the ZCU102 board */
			clocks = <&refhdmi>;
			clock-names = "xtal_0";
			/* output clock */
			clk0 {
				reg = <0>;
				/* HDMI TX reference clock output frequency */
				clock-frequency = <27000000>;
		/* DP159 exposes a virtual CCF clock. Upon .set_rate(), it adapts its retiming/driving behaviour */
		dp159: hdmi-retimer@5e {
			status = "okay";
			compatible = "ti,dp159";
			reg = <0x5e>;
			#size-cells = <0>;
			#clock-cells = <0>;
    axi_stream_clk: axi_stream_clk {
		compatible = "fixed-factor-clock";
		clocks = <&clk 71>;
		#clock-cells = <0>;
		clock-div = <1>;
		clock-mult = <6>;
	axi_lite_clk: axi_lite_clk {
		clocks = <&clk 71>;
		#clock-cells = <0>;
		clock-div = <1>;
		clock-mult = <1>;
&Video_PHY {
	compatible = "xlnx,vid-phy-controller-2.2";
	reg = <0x0 0xa0040000 0x0 0x10000>;
	/* interrupts = <3 2>; */
	clocks = <&axi_lite_clk>, <&si570_2>;
	clock-names = "axi-lite", "dru-clk";
	xlnx,input-pixels-per-clock = <0x2>;
	xlnx,nidru = <0x1>;
	xlnx,nidru-refclk-sel = <0x4>;
	xlnx,rx-no-of-channels = <0x3>;
	xlnx,rx-pll-selection = <0x0>;
	xlnx,rx-protocol = <0x1>;
	xlnx,rx-refclk-sel = <0x1>;
	xlnx,tx-no-of-channels = <0x3>;
	xlnx,tx-pll-selection = <0x6>;
	xlnx,tx-protocol = <0x1>;
	xlnx,tx-refclk-sel = <0x0>;
	xlnx,hdmi-fast-switch = <0x1>;
	xlnx,transceiver-type = <0x5>;
	xlnx,tx-buffer-bypass = <0x1>;
	xlnx,transceiver-width = <0x2>;
	vphy_lane0: vphy_lane@0 {
		#phy-cells = <4>;
	vphy_lane1: vphy_lane@1 {
		#phy-cells = <4>;
	vphy_lane2: vphy_lane@2 {
		#phy-cells = <4>;
	vphy_lane3: vphy_lane@3 {
		#phy-cells = <4>;
&HDMI_TX {
	compatible = "xlnx,v-hdmi-tx-ss-3.1";
	reg = <0x0 0xa0020000 0x0 0x20000>;
	reg-names = "hdmi-txss";
	/* interrupts = <4 2>; */
	/* interrupt-names = "hdmitx"; */
	interrupts = <0 92 4>;
	interrupt-names = "hdmitx", "hdcp1x", "hdcp1x-timer", "hdcp22", "hdcp22-timer";
	clocks = <&axi_lite_clk>, <&axi_stream_clk>, <&si5324 0>, <&dp159>;
	clock-names = "axi-lite", "video", "txref-clk", "retimer-clk";
	phys = <&vphy_lane0 0 1 1 1>, <&vphy_lane1 0 1 1 1>, <&vphy_lane2 0 1 1 1>;
	phy-names = "hdmi-phy0", "hdmi-phy1", "hdmi-phy2";
	xlnx,input-pixels-per-clock = <2>;
	xlnx,max-bits-per-component = <8>;
	xlnx,output-fmt = "rgb";
&HDMI_RX {
	compatible = "xlnx,v-hdmi-rx-ss-3.1";
	reg = <0x0 0xa0000000 0x0 0x10000>;
	reg-names = "hdmi-rxss";
	/* interrupts = <2 2>; */
	/* interrupt-names = "hdmirx"; */
	interrupts = <0 90 4>;
	clocks = <&axi_lite_clk>, <&axi_stream_clk>;
	clock-names = "axi-lite", "video";
	phys = <&vphy_lane0 0 1 1 0>, <&vphy_lane1 0 1 1 0>, <&vphy_lane2 0 1 1 0>;
	xlnx,edid-ram-size = <0x100>;
The AXI4-S video goes from RX-SS to TX-SS. I'm using HDMI-to-DVI digital cables, so the ACR audio is disconnected as there's nothing there anyway.
Why is there no locked link on the TX side?
Thanks!
@dima2882
There is a known issue in HDMI v2018.3 DRM TX driver when using HDMI to DVI converter.
This issue has been fixed in https://github.com/Xilinx/hdmi-modules/blob/master/hdmi/xilinx_drm_hdmi.c
We have added following code to check if HDMI Sink is DVI or not, and switch HDMI TX to DVI mode :
/* If the sink is non HDMI, set the stream type to DVI else HDMI */
is_hdmi_sink = drm_detect_hdmi_monitor(edid);
if(is_hdmi_sink) {
XV_HdmiTxSs_SetVideoStreamType(&xhdmi->xv_hdmitxss, 1);
dev_dbg(xhdmi->dev, "EDID shows HDMI sink is connected, setting stream type to HDMI\n");
} else {
XV_HdmiTxSs_SetVideoStreamType(&xhdmi->xv_hdmitxss, 0);
dev_dbg(xhdmi->dev, "EDID shows non HDMI sink is connected, setting stream type to DVI\n");
This fix will be contained in 2019.1.
@dima2882
if(is_hdmi_sink) {
} else {
Brilliant, will try with that change. Thanks for your help.
Hi @dima2882 ,
Do you have any update on this? Did you try the change? Did it helped?
Thanks and Regards,
Unfortunately, the patch suggested above had no effect - that code doesn't even get executed.
What made things work in the end is adding the right port in the TX-SS DTS as well as pointing that port to a DMA node.
Apparently, the Xilinx TX-SS drivers expect the HDMI flow to go through the CPU and originate there. So, even in a pure passthrough design, in order to get the driver to behave in a pure streaming way that doesn't touch the CPU, it needs to have a node in the device tree as if there's a memory pathway via DMA.
@dima2882
As 2019.1 is out, I strongly suggest you upgrade to this version for two reasons :
1. The DVI adapter issue has been fixed in HDMI 2019.1 driver
2. In 2018.3, HDMI/Video PHY device trees are not auto-generated from DTG. This has been fixed in 2019.1. In 2019.1, DTG can automatically check what is connected to HDMI TX input/output, necessary Device tree node is generated accordingly. It doesn't need user to manually add addition node for DMA access, or create dtsi file.
Please upgrade your design to 2019.1, and create Petalinux 2019.1 project with ZCU102 bsp, you shouldn't see this issue.
On it, will test with 2019.1 this weekend.
Hi @dima2882
Do you have any update on this? Were you able to test?
