garryc3
No video out of AXI stream to video out IP
I have create a subsystem with a video being input using HDMI which is then converted to AXI steam using the video in to AXI stream IP. I then use the video timing block to generate the timing for the AXI stream to video out IP and the data stream for this comes straight from video in to AXI stream IP, the video is finally output using VGA.
My issue is I'm not seeing any video out of the VGA when I connect the system like this, it works fine when I connect the video out from the HDMI directly to the video in of the VGA. I piped the locked signal of the AXI stream to video out and it never gets asserted, I think my issue may be with the video timing block. I want to us the AXI stream to video out IP in slave mode where the video timing block is detects the video timing from the video in to AXI stream and generates the timing for the AXI stream to video out.
I have a attached two pictures one of the subsystem and one of the features I am using in the timing block. Can someone tell me if I am using the features for the mode I want to use or if there is something else I might be doing wrong?
watari
Hi @garryc3
Did you describe C source code for control these IPs ?
If no, you need to prepare control code for these IPs.
florentw
@garryc3,
1. Are you getting the lock signal from the AXI4-Stream to video out?
2. If not, is the underflow output high? If yes, check why you do not have enough data coming in
3. If not, make sure the size from you input and the size configured in your VTC generator match
 @watari,
There is no need for C code as they do not have the AXI4-Lite interface enabled.
garryc3
I didn't think I needed C code to control this IP? I have removed the AXI lite interface from the IP so I assumed the video timing detection and generation would work automatically, is this now the case?
florentw
Hi @garryc3,
Did you see my reply on this? Does it help?
garryc3
Hi Florent,
Yes I did see your reply and here is my response to your questions
- No the lock signal from the axis to video out IP is not set
- Yes the underflow signal is being asserted for axis to video out IP
- Yes there is data flowing into axis to video out IP from the video in to axis IP(shown in  the image)
I think the format setting in the VTC and it is set to 720p which is the video format I am using in the Diligent dvi2rgb IP. I assume setting the VTC to 720p should be enough to ensure they match?
Cathal
florentw
Hi @garryc3,
If the underflow signal is high, it might be that your input data stream is not fast enough for you output video.
You might want to try adding a VDMA or a FIFO before the AXI4-Stream to video out. It might help.
garryc3
Hi Florent,
I tried inserting a AXI stream data FIFO before the video out but I'm still getting an underflow issue. Can the VDMA be setup to automatically stream data through it or does it need a driver? Do you have any examples applications that use the VDMA like this?
Cathal
florentw
Hi @garryc3,
The VDMA needs some configuration (Hstride/Hsize and Vsize). There is an example design for the VDMA (refer to its product guide).
watari
Hi @garryc3
If you already set some parameters by software or something on VDMA and the result is same as before, I suggest to fix floating port at "AXI4Stream to Video Out" module.
Would you try it ?
garryc3
Hi Florent,
From looking at the VDMA spec it looks like you need some form of a driver to pass AXI stream data through the block. Is there anyway to use this block without a driver?
On the fix floating port comment, I'm not sure what you are asking here? Are you suggesting to leave the AXI stream to video out port hanging? If so what would this achieve?
Cathal
florentw
Hi @garryc3
> You need to configure the register. I highly recommend you to use the drivers or a processor configuring the registers directly. However you should be able to do your own IP to do the AXI transactions
> This comment is from @watari. I think from his experience, making sure that all the port are connected to a known value (i.e. no floating point) can solve the issue.
florentw
HI @garryc3,
Do you still have issues? If it is solved, could you kindly mark a reply as accepted solution to close the topic?
If not, you might want to have a look to my latest Video Beginner Series 8: Debugging the AXI4-Stream to Video Out IP. This could help you understand why it is not working.
garryc3
Yes I'm still having the issue as I can't manage to get the VDMA to work while trying to stream it. Am I correct in assuming a AXI streaming FIFO should work just as well as a VDMA?
Ok I'll have a look at this blog.
Cathal
florentw
Hi @garryc3,
Yes you should be fine with an AXI4-Stream FIFO
garryc3
Hi Florent,
Unfortunately due to the lack of logic on the zybo platform I can't view the debug bus on the AXI stream to RGB. I'm trying to switch to the pynq platform now since this has more logic but unless you have any other suggestion I don't think I can debug this any further.
Cathal
florentw
Hi @garryc3,
You can try to remove some part of your design for now.
Or you can try in simulation.
florentw
HI @garryc3,
Do you have any updates on this? Did you fix your issue?
garryc3
Hi Florent,
No sorry I haven't had a chance yet, I'll update this once I get a chance to debug it further.
Cathal
florentw
HI @garryc3,
Do you have any updates on this? Is it working now?
Thanks and Regards,
garryc3
Hi Florent,
Sorry for the delay in my response. No I was able to get this working and I had to use a different solution for my project in order to overcome this. My project is finishing up now so I'm not sure what to do with this ticket? Any suggestion, should it just be left open?
Cathal
florentw
Hi @garryc3,
Thanks for the update.
As this is not solved, you can leave it. You can come back to this if you are faced to this issue again.
