shree9_7
Not able to generate Test patterns for Native Video stream !
Hello Support Team,
I am struggling to generate the Test Pattern signals to test the DisplayPort TX subsystem design. The design is based on the reference design from below link.
https://github.com/laurivosandi/hdl/blob/master/zynq/xilinx-test-pattern-generator.rst
I modified the video test pattern generator example as per the design but when I flashed the code on board and checked the waveforms using ILA then there was no signals. I have also attched the code snippet for your reference.
int driverInit()
	int status;
	vtc_Config = XVtc_LookupConfig(XPAR_V_TC_0_DEVICE_ID);
	if(vtc_Config == NULL)
		xil_printf("ERR:: VTC device not found\r\n");
		return(XST_DEVICE_NOT_FOUND);
	status = XVtc_CfgInitialize(&vtc, vtc_Config, vtc_Config->BaseAddress);
	if(status != XST_SUCCESS)
		xil_printf("ERR:: VTC Initialization failed %d\r\n", status);
		return(XST_FAILURE);
	tpg1_Config = XV_tpg_LookupConfig(XPAR_V_TPG_0_DEVICE_ID);
	if(tpg1_Config == NULL)
		xil_printf("ERR:: TPG device not found\r\n");
	status = XV_tpg_CfgInitialize(&tpg1, tpg1_Config, tpg1_Config->BaseAddress);
		xil_printf("ERR:: TPG Initialization failed %d\r\n", status);
	return(XST_SUCCESS);
void videoIpConfig(XVidC_VideoMode videoMode)
	XVidC_VideoTiming const *timing = XVidC_GetTimingInfo(videoMode);
	u16 PixelsPerClk;
	int status;
	status = XV_tpg_IsReady(&tpg1);
	printf("Status %u \n\r", (unsigned int) status);
	status = XV_tpg_IsIdle(&tpg1);
	XV_tpg_Set_height(&tpg1, timing->VActive);
	XV_tpg_Set_width(&tpg1, timing->HActive);
	XV_tpg_Set_colorFormat(&tpg1, 0);
	XV_tpg_Set_bckgndId(&tpg1, XTPG_BKGND_COLOR_BARS);
	XV_tpg_Set_ovrlayId(&tpg1, 0);
	XV_tpg_Set_enableInput(&tpg1, 1);
	XV_tpg_Set_passthruStartX(&tpg1, 0);
	XV_tpg_Set_passthruStartY(&tpg1, 0);
	XV_tpg_Set_passthruEndX(&tpg1, timing->HActive);
	XV_tpg_Set_passthruEndY(&tpg1, timing->VActive);
	XV_tpg_EnableAutoRestart(&tpg1);
	XV_tpg_WriteReg(tpg1_Config->BaseAddress, XV_TPG_CTRL_ADDR_AP_CTRL, 0x81);
	PixelsPerClk = tpg1.Config.PixPerClk;
	vtc_timing.HActiveVideo  = timing->HActive/PixelsPerClk;
	vtc_timing.HFrontPorch   = timing->HFrontPorch/PixelsPerClk;
	vtc_timing.HSyncWidth    = timing->HSyncWidth/PixelsPerClk;
	vtc_timing.HBackPorch    = timing->HBackPorch/PixelsPerClk;
	vtc_timing.HSyncPolarity = timing->HSyncPolarity;
	vtc_timing.VActiveVideo  = timing->VActive;
	vtc_timing.V0FrontPorch  = timing->F0PVFrontPorch;
	vtc_timing.V0SyncWidth   = timing->F0PVSyncWidth;
	vtc_timing.V0BackPorch   = timing->F0PVBackPorch;
	vtc_timing.VSyncPolarity = timing->VSyncPolarity;
	XVtc_SetGeneratorTiming(&vtc, &vtc_timing);
	XVtc_Enable(&vtc);
	XVtc_EnableGenerator(&vtc);
	XVtc_RegUpdateEnable(&vtc);
Also I have some doubts about the design which are as below:
1) Is it required to use the reconfigurable Clock wizard in the design ?
2) If I don't use the reconfigurable Clock wizard in the design then do I need to use the videoClockConfig() function in my code ?
Thanks in advance,
Shree9_7
florentw
[Florent] - I wrote some blog articles as part of my video series.
One is showing the TPG working in simulation
Video Beginner Series 4: Simulation with the Xilinx TPG IP
and the other is showing the TPG working in HW
Video Series 21: TPG Application on ZC702
If you have no data out, you might want to make sure the tready from the downstream IP is high. This is something I shared in my Video Series 31 – Debugging a Video System using an ILA
[Florent] - Well, if you are planning to do a native interface, yes you need to adapt the pixel clock. Video Series 22: Supporting multiple video resolutions on ZC702 HDMI might be a good read for you. Again as per your previous topic, it would probably be much easier for you to use the AXI4-Stream interface of the DP SS IP
[Florent]  - I guess not I haven't read the code
PS: Could you kindly close your previous topic by marking it as solved as you have now this current topic opened?
Thanks in advance,
Shree9_7
florentw
Thanks in advance,
Shree9_7
samk
Hi @shree9_7,
 Was florentw's response able to answer yoru questions?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
