OSD license for mass production
Dears
We were developing a product platform based on OSD with Hardware Emulation license. Currently we're releasing the design and planning mass production. So we'd like to get an OSD license.
However, we found out OSD IP is not recommanded by Xilinx for new design, therefore the IP license can't be applied on internet. We tried to use Video Mixer to replace OSD but found many bugs. It's not easy to solve them in short time.
My question is, how can I apply a OSD license for product now?
My tool version is 2019.1, and my previous tool version is 2015.4.
Thanks a lot.
Hi @xingwang_chen
You can try to contact the Authorized Distributor you are usually buying part from to see if they can do anything for you.
Hi @xingwang_chen
As per the product page for the OSD, this IP is obsoleted so you will not be able to get a license for it.
You should consider moving to the Video Mixer IP which is available for free in vivado. If you faces issues with the Video Mixer, you might want to start by reporting them to get them fixed (looking at your profile, you have never created any topics related to the Video Mixer)
Thank you for the reply. However I don't think it's a solution for us. We can try to use video mixer IP in our next generation product but not this one. It's medical device and we completed a very complete design, verification and validation process. It's not easy at this moment to use a completely new IP to replace a stable one.
Could you please reconsider this?
Thanks a lot.
Hi @xingwang_chen
Hi @xingwang_chen,
Is everything clear for you on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
Thanks everybody. I've already got solution from Xilinx via the distributor. The license is working well. Thanks again!
