ivanfan
Ony DL0 of D-Phy work in HS_MODE in CSI RX subsystem example design
I'm using the MIPI CSI-2 RX subsystem on the Xilinx ZCU102 board with my own camera sensor. The sensor sends 12bit raw image with 1280x720 resolution at 66 fps in two mipi data line.
The problem I meet was posted in the follow link D-PHY module can output signal but no video_out in mipi csi example design   And now I found the reason might be that I set two active line but only dataline0 works in HS_MODE and dataline1 is fixed in LP_MODE. Would the error setting of line rate make such problem happen?
The data sheet of the sensor I use does not mention the output rate of the sensor. I do not know how much the line rate should be set in the config of D-Phy. Can we calculate it according to the resolution and fps of the sensor?
Any help regarding the issue will be appreciated. The status of registers of D-Phy are shown as follow:
Tags (2)
karnanl
Hello @ivanfan
No, we cannot. This is not possible.
>The data sheet of the sensor I use does not mention the output rate of the sensor. I do not know how much the line rate should be set in the config of D-PHY
Hmm, I would suggest to contact the distributor of the sensor for help. ( Perhaps user guide/datasheet may also help )
BTW, Do you have an oscilloscope on your lab ? Could you please take the waveform of data_lane0 and data_lane1 ?
I am suspecting that your data_lane1 is actually sending LP-11.
Thanks & regards
Leo
Versal Blogs
ivanfan
The waveforms of data_lane0 and data_lane1 in oscilloscope
DataLine0P
DataLine1P
karnanl
Hello @ivanfan
Thank you for sharing the waveform capture.
My understanding is either :
a. HS signal swing level on data_lane_1 is too small. ( damaged sensor ?! )
b. Your sensor is only sending one lane. ( If this is the case, I would expect that data_lane_1 will be in LP-11. Not toggling HS<->LP )
(1) Would it possible to use another sensor ? ( Do you have another sensor with the same model )
(2) Are you sure sensor is sending MIPI CSI-2 with 2lane configuration ? ( Could you please check with sensor maker/distributor ? )
Leo
Versal Blogs
ivanfan
My camera sensor is connected to the fmc interface via the DuPont line as shown below.
What surprised me is that after the camera register configuration is completed, I pull out the line of clk and reconnect it, the DL1 can receive packet and work in HS_MODE. And I can get the image output from HDMI.
Why does the DL1 work only after I reconnect the clk line? Is this related to the initialization process of DPHY? If I don't want to reconnect the clk line every time I launch the program, what should I do?
karnanl
Hello @ivanfan
This behavior is not expected. DL1 should work without connect/reconnect clock line.
BTW, Do you connect the GND of both boards ? If not could you please try to connect the GND of your boards ?
Perhaps Joe debug experience can be a useful information for you too.
https://forums.xilinx.com/t5/Video/DPHY-RX-clock-debug/m-p/1066522
Thanks & regards
Leo
Versal Blogs
bpatil
Hello @ivanfan
According to me, using dupont wires for interfacing High speed interface as such as MIPI is not at all good idea. Eventhough wire quality is good; sometimes due to multiple insertion/ejection of dupont connectors and movement of wires can degrade quality of signal. I believe you should find for more rigid way (like small breakout board which can be connected FMC card) to connect MIPI camera to your FPGA board.
Bhushan
