ackye
Open the SDK project of xapp1249 with VITIS, no source code can be imported
Vivado’s FPGA hardware project is imported without any problems, but when I use vitis to import the project, I can’t see any code
I also tried to import the resource directly to import the code (.c.h) but it cannot be compiled.
The import path is also set according to the PDF (<unzip_dir>\xapp1249\srcs\fidus_fmc_ctlr\SW)
florentw
Hi @ackye
Did you try first with 2018.1? Note that the XAPP is officially supported only for the version it was created.
Vitis is a bit different than SDK. Even for SDK I would not recommend to import workspace directly between different versions.
You might want to create a new bare metal application running on the microblaze on your Hw_1 platform. The use the empty template and manually import the c files individually
Florent
