OpenGLES tricube tutorial on zcu106
I'm currently trying to follow the tutorial "Example Setup for Graphics and Display Port Based Sub-System" from ug1209 (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1209-embedded-design-tutorial.pdf). The idea of this tutorial is to display through the DisplayPort some 3D shapes thanks to OpenGLES.
This last is designed for the ZCU102 evaluation and I have the last ZCU106. My monitor is a iiYama Prolite E2280HS.
During the tutorial, the following device tree patch is applied (cf. https://www.xilinx.com/support/answers/69248.html)
&tca6416_u97 {
gtr_sel0 {
/delete-property/ output-low; /* PCIE = 0, DP = 1 */
output-high; /* PCIE = 0, DP = 1 */
The application has not problem to run but when I analyse the Xorg log, it seems that the minotor is not detected:
Xorg.0.log:
[ 522.181]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[ 522.181] X Protocol Version 11, Revision 0
[ 522.181] Build Operating System: Linux 3.10.0-327.el7.x86_64 x86_64
[ 522.181] Current Operating System: Linux xilinx-zcu106-2018_2 4.14.0-xilinx-v2018.2 #1 SMP Tue Oct 9 17:24:13 CEST 2018 aarch64
[ 522.181] Kernel command line: earlycon clk_ignore_unused
[ 522.181] Build Date: 11 June 2018 06:52:05PM
[ 522.181]
[ 522.181] Current version of pixman: 0.34.0
[ 522.181] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 522.181] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 522.181] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 10 08:54:14 2018
[ 522.182] (==) Using config file: "/etc/X11/xorg.conf"
[ 522.182] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 522.182] (==) No Layout section. Using the first Screen section.
[ 522.182] (**) |-->Screen "DefaultScreen" (0)
[ 522.182] (**) | |-->Monitor "<default monitor>"
[ 522.182] (**) | |-->Device "ZynqMP"
[ 522.182] (==) No monitor specified for screen "DefaultScreen".
Using a default monitor configuration.
[ 522.182] (==) Automatically adding devices
[ 522.182] (==) Automatically enabling devices
[ 522.182] (==) Automatically adding GPU devices
[ 522.183] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 522.183] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
[ 522.183] Entry deleted from font path.
[ 522.183] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[ 522.183] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[ 522.183] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[ 522.183] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 522.183] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 522.183] (==) FontPath set to:
[ 522.183] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 522.183] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 522.183] (II) Loader magic: 0x5bfc00
[ 522.183] (II) Module ABI versions:
[ 522.183] X.Org ANSI C Emulation: 0.4
[ 522.183] X.Org Video Driver: 23.0
[ 522.183] X.Org XInput driver : 24.1
[ 522.183] X.Org Server Extension : 10.0
[ 522.183] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 522.183] (II) no primary bus or device found
[ 522.183] falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[ 522.183] (II) LoadModule: "glx"
[ 522.184] (WW) Warning, couldn't open module glx
[ 522.184] (II) UnloadModule: "glx"
[ 522.184] (II) Unloading glx
[ 522.184] (EE) Failed to load module "glx" (module does not exist, 0)
[ 522.184] (II) LoadModule: "armsoc"
[ 522.184] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 522.184] (II) Module armsoc: vendor="X.Org Foundation"
[ 522.184] compiled for 1.19.3, module version = 1.4.1
[ 522.184] Module class: X.Org Video Driver
[ 522.184] ABI class: X.Org Video Driver, version 23.0
[ 522.184] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[ 522.185] (--) using VT number 3
[ 522.185] (WW) Falling back to old probe method for armsoc
[ 522.185] (II) No BusID or DriverName specified - opening /dev/dri/card0
[ 522.185] (II) Got BusID fd4a0000.zynqmp-display
[ 522.185] (II) Opened DRM
[ 522.185] (II) DeviceName is [/dev/dri/card0]
[ 522.185] (II) bus_id is [fd4a0000.zynqmp-display]
[ 522.185] (II) DriverName is [xlnx]
[ 522.185] (II) version is [1.0.0]
[ 522.185] (II) Screen:0, CRTC:-1
[ 522.185] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 522.185] (II) ARMSOC(0): Creating default Display subsection in Screen section
"DefaultScreen" for depth/fbbpp 16/16
[ 522.185] (++) ARMSOC(0): Depth 16, (--) framebuffer bpp 16
[ 522.185] (==) ARMSOC(0): RGB weight 565
[ 522.185] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[ 522.185] (==) ARMSOC(0): Default visual is TrueColor
[ 522.186] (II) Opened DRM
[ 522.186] (II) DeviceName is [/dev/dri/card0]
[ 522.186] (II) bus_id is [fd4a0000.zynqmp-display]
[ 522.186] (II) DriverName is [xlnx]
[ 522.186] (II) version is [1.0.0]
[ 522.186] (II) ARMSOC(0): Chipset: Mali
[ 522.186] (**) ARMSOC(0): Option "Debug" "false"
[ 522.186] (II) ARMSOC(0): Buffer Flipping is Enabled
[ 522.186] (II) ARMSOC(0): umplock is Enabled
[ 522.186] (II) ARMSOC(0): Setting the video modes ...
[ 522.186] (II) ARMSOC(0): Adding all CRTCs
[ 522.186] (II) ARMSOC(0): Got CRTC: 0 (id: 36)
[ 522.204] (II) ARMSOC(0): Output DP-1 has no monitor section
[ 522.223] (II) ARMSOC(0): EDID for output DP-1
[ 522.223] (II) ARMSOC(0): Output DP-1 disconnected
[ 522.223] (WW) ARMSOC(0): No outputs definitely connected, trying again...
[ 522.223] (WW) ARMSOC(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[ 522.223] (II) ARMSOC(0): Got KMS resources
[ 522.223] (==) ARMSOC(0): DPI set to (96, 96)
[ 522.223] (II) Loading sub module "dri2"
[ 522.223] (II) LoadModule: "dri2"
[ 522.223] (II) Module "dri2" already built-in
[ 522.223] (II) Loading sub module "exa"
[ 522.223] (II) LoadModule: "exa"
[ 522.224] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 522.224] (II) Module exa: vendor="X.Org Foundation"
[ 522.224] compiled for 1.19.3, module version = 2.6.0
[ 522.224] ABI class: X.Org Video Driver, version 23.0
[ 522.224] (II) Loading sub module "fb"
[ 522.224] (II) LoadModule: "fb"
[ 522.224] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 522.224] (II) Module fb: vendor="X.Org Foundation"
[ 522.224] compiled for 1.19.3, module version = 1.0.0
[ 522.224] ABI class: X.Org ANSI C Emulation, version 0.4
[ 522.225] (II) ARMSOC(0): Soft EXA mode
[ 522.225] (II) EXA(0): Driver allocated offscreen pixmaps
[ 522.225] (II) EXA(0): Driver registered support for the following operations:
[ 522.225] (II) Solid
[ 522.225] (II) Copy
[ 522.225] (II) Composite (RENDER acceleration)
[ 522.225] (II) ARMSOC(0): Setting swap chain size: 2
[ 522.225] (II) ARMSOC(0): [DRI2] Setup complete
[ 522.225] (II) ARMSOC(0): [DRI2] DRI driver: armsoc
[ 522.225] (==) ARMSOC(0): Backing store enabled
[ 522.225] (==) ARMSOC(0): Silken mouse enabled
[ 522.226] (II) ARMSOC(0): HW cursor init()
[ 522.226] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 522.226] (==) ARMSOC(0): DPMS enabled
[ 522.226] (--) RandR disabled
[ 522.305] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[ 522.305] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[ 522.305] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[ 522.306] (II) LoadModule: "libinput"
[ 522.306] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 522.307] (II) Module libinput: vendor="X.Org Foundation"
[ 522.307] compiled for 1.19.3, module version = 0.25.1
[ 522.307] Module class: X.Org XInput Driver
[ 522.307] ABI class: X.Org XInput driver, version 24.1
[ 522.307] (II) Using input driver 'libinput' for 'gpio-keys'
[ 522.307] (**) gpio-keys: always reports core events
[ 522.307] (**) Option "Device" "/dev/input/event0"
[ 522.307] (**) Option "_source" "server/udev"
[ 522.307] (II) event0 - (II) gpio-keys: (II) is tagged by udev as: Keyboard
[ 522.307] (II) event0 - (II) gpio-keys: (II) device is a keyboard
[ 522.308] (II) event0 - (II) gpio-keys: (II) device removed
[ 522.348] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[ 522.348] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[ 522.349] (II) event0 - (II) gpio-keys: (II) is tagged by udev as: Keyboard
[ 522.349] (II) event0 - (II) gpio-keys: (II) device is a keyboard
The xorg.conf is:
Section "InputDevice"
Identifier "System Mouse"
Driver "mouse"
Option "Device" "/dev/input/mouse0"
EndSection
Identifier "System Keyboard"
Driver "kbd"
EndSection
Section "Device"
Identifier "ZynqMP"
Driver "armsoc"
Option "DRI2" "true"
Option "DRI2_PAGE_FLIP" "false"
Option "DRI2_WAIT_VSYNC" "true"
Option "SWcursorLCD" "false"
Option "DEBUG" "false"
EndSection
Section "Screen"
Identifier "DefaultScreen"
Device "ZynqMP"
DefaultDepth 16
Any ideas?
I tried with a iiyama prolite xb2483hsu which has a DP and it works!
First question:
Does the patch :
&tca6416_u97 {
gtr_sel0 {
Which is for hte ZCU102, should be the same for ZCU106 ?
(I tried with/without and it made no differences.)
Hi user@moduleus,
Did you try to use the pre-built images for ZCU106 to make sure the DP can work with the monitor you are using?
Thanks for your answer.
I tried and I get the same/var/log/Xorg.0.log .
Does it need any other set-up? I also tried the following cmds:
killall Xorg
export DISPLAY=:0.0
Xorg -depth 16 &
But same issue.
I suppose it is an incompatibility issue with my display monitor.
Hi user@moduleus
I confirmed your log file and your monitor specification.
This LCD monitor doesn't support Display Port.
How do you connect it to this LCD monitor ?
Would you make sure to use an active adapter, if you connect it by HDMI or DVI via DisplayPort ?
Also, according to log file, X doesn't read EDID value via DDC.
I suggesto to make sure a cable, too.
Yes, my monitor doesn't support directly Display Port. So, I use a cable Display Port to DVI but it is not an active one.
I will get and try with an active adapter.
