PG230: video phy controller
can the register  work because they have been tied 0 inside RTL code?
Hi @ha4456
Do you have any updates on this? Did my reply clarify things?
Florent
Hi @ha4456
You are not mentioning which configuration of the Video PHY you used. But anyway, I just think you are looking at the incorrect section of the code. I have tried with the Video PHY configured for HDMI TX and RX.
Checking where the gtwizard is instantiated, I can see that these signals coming from the registers are connected and used. Example with GTTXRESET:
Florent
Hi @ha4456
Florent
