PLB DVI controller for ISE
hai,
I have an Issue that MY RGB[24:0] Data in single port ram .How can i give the data to dvi controller? in ISE
I dig the  PLB dvi controller core  in ISE environment some what in that 4 modules are there
v_sync,hysnc,BRAM,TFT_if out of which vsnc,hsync are common to display .How can i remove BRAM and put single port
I'm not sure I understand the question.
Is this a core from an example design that you want modify?
Chris
Versal ACAP: AI Engines | Embedded SW Support
